1. Introduction
The serial port found on the back of most PCs is extremely useful for robotics work. A variety of devices are configured to communicate via a serial port, and you can use it to debug or control your own projects. This project shows you how to use free tools to write programs that use your serial port. We’ll show you how to make your programs compatible with both Microsoft Windows and Linux, and present a method for creating simple graphical interfaces. We will assume you know a bit of C and are comfortable installing software on your computer. Knowing Linux commands like cd, mkdir, and ls will also be helpful.
New Products
Pololu Reverse Voltage Protector, 4-60V, 12A
ACS37042KLHBLT-010B3 Current Sensor Compact Carrier -10A to +10A, 3.3V
12V, 500mA Step-Down Voltage Regulator D45V5F12
Pololu High-Power Stepper Motor Driver 36v8
A5984 Stepper Motor Driver Carrier, Fixed 1.5A@5V / 1A@3.3V, Blue Edition (Soldered Header Pins)
ACS37220LEZATR-200B5 Current Sensor Compact Carrier -200A to +200A, 5V
Pololu H2 High-Power Motor Driver 36v11 CS
ACS37220LEZATR-100B5 Current Sensor Large Carrier -100A to +100A, 5V
ACS37800KMACTR-030B3-I2C Power Monitor Carrier with Secondary I²C Isolation
A5984 Stepper Motor Driver Carrier, Fixed 500mA@5V / 330mA@3.3V
