2. Materials
Here’s what you’ll need to follow along:
  • Pololu 16-servo controller (that’s what we’ll use; you could use any other serial device)
  • A PC with a serial port running Microsoft Windows or Linux. If your PC doesn’t have a serial port, USB serial port adapters are available for just a few dollars.
  • A serial cable to connect your device to the computer. For most devices, a “modem” or “extension” cable is what you want. Don’t get a “null modem” or “crossover” cable unless you know you need it.
New Products
Isolated DC-DC Power Module, UCC33420, 5V/5.5V, 300mA
APM81815 Step-Down Voltage Regulator Carrier, 3.3V Out
ACS37200LLXTR-200B3 Current Sensor Large Carrier -200A to +200A, 3.3V
Pololu Reverse Voltage Protector, 4-75V, 17A
4.4:1 Metal Gearmotor 25Dx48L mm HP 24V
ACS37030LMYATR-040B3 Current Sensor Large Carrier -40A to +40A, 3.3V
ACS37200LLXTR-200B5 Current Sensor Large Carrier -200A to +200A, 5V
