15.9. Example I²C code for Linux in Python
The example code below uses a Python library named smbus2 to send and receive data from a Jrk G2 via I²C. It demonstrates how to set the target of the Jrk by sending a “Set target” command and how to read variables using a “Get variables” command. This example works on Linux with either Python 2 or Python 3. This example is very similar to the example in Section 15.8, except that it uses Python instead of C.
If you are using a Raspberry Pi, please see the notes about setting up I²C for the Raspberry Pi in Section 15.8.
To install the smbus2 library, you will need to run either pip install smbus2 or pip3 install smbus2 depending on what version of Python you want to use and what Linux distribution you are using. On Raspbian, pip is for Python 2 and pip3 is for Python 3.
# Uses the smbus2 library to send and receive data from a Jrk G2.
# Works on Linux with either Python 2 or Python 3.
# NOTE: The Jrk's input mode must be "Serial / I2C / USB".
# NOTE: For reliable operation on a Raspberry Pi, enable the i2c-gpio
#   overlay and use the I2C device it provides (usually /dev/i2c-3).
# NOTE: You might nee to change the 'SMBus(3)' line below to specify the
#   correct I2C device.
# NOTE: You might need to change the 'address = 11' line below to match
#   the device number of your Jrk.
from smbus2 import SMBus, i2c_msg
class JrkG2I2C(object):
  def __init__(self, bus, address):
    self.bus = bus
    self.address = address
  # Sets the target.  For more information about what this command does,
  # see the "Set Target" command in the "Command reference" section of
  # the Jrk G2 user's guide.
  def set_target(self, target):
    command = [0xC0 + (target & 0x1F), (target >> 5) & 0x7F]
    write = i2c_msg.write(self.address, command)
    self.bus.i2c_rdwr(write)
  # Gets one or more variables from the Jrk (without clearing them).
  # Returns a list of byte values (integers between 0 and 255).
    write = i2c_msg.write(self.address, [0xE5, offset])
    read = i2c_msg.read(self.address, length)
    self.bus.i2c_rdwr(write, read)
    return list(read)
  # Gets the Target variable from the Jrk.
  def get_target(self):
    b = self.get_variables(0x02, 2)
    return b[0] + 256 * b[1]
  # Gets the Feedback variable from the Jrk.
  def get_feedback(self):
    b = self.get_variables(0x04, 2)
# Open a handle to "/dev/i2c-3", representing the I2C bus.
bus = SMBus(3)
# Select the I2C address of the Jrk (the device number).
address = 11
jrk = JrkG2I2C(bus, address)
feedback = jrk.get_feedback()
print("Feedback is {}.".format(feedback))
target = jrk.get_target()
print("Target is {}.".format(target))
new_target = 2248 if target < 2048 else 1848
print("Setting target to {}.".format(new_target))
jrk.set_target(new_target)
