Support » Jrk G2 Motor Controller User’s Guide » 15. Writing PC software to control the Jrk »
15.2. Example code to run jrk2cmd in Ruby
The example Ruby code below shows how to invoke the Jrk G2 Command-line Utility (jrk2cmd) to send and receive data from a Jrk G2 via USB. It demonstrates how to set the target of the Jrk using the --target
option and how to read variables using the -s
option. This code uses the YAML parser that comes with Ruby to parse the output of jrk2cmd
when reading data from the Jrk. This code should work on any system with jrk2cmd and Ruby.
If you have multiple Jrk G2 devices connected to your computer via USB, you will need to use the -d
option to specify the serial number of the device you want to use. For example, to get the status of the Jrk G2 with serial number 00123456, you can run the Ruby code jrk2cmd('-d', '00123456', '-s', '--full')
. You can run jrk2cmd --list
in a shell to get the serial numbers of all the connected Jrk G2 devices.
In the example below, the child jrk2cmd process uses the same error pipe as the Ruby process, so you will see any error messages printed by jrk2cmd if you run the Ruby program in a terminal. If you want to instead capture the standard error output so that you can use it in your Ruby program, you can change the code to use Ruby’s Open3.capture3
method.
# Uses jrk2cmd to send and receive data from the Jrk G2 over USB. # # NOTE: The Jrk's input mode must be "Serial / I2C / USB". require 'open3' require 'yaml' def jrk2cmd(*args) command = 'jrk2cmd ' + args.join(' ') stdout, process_status = Open3.capture2(command) if !process_status.success? raise "Command failed with code #{process_status.exitstatus}: #{command}" end stdout end status = YAML.load(jrk2cmd('-s', '--full')) feedback = status.fetch('Feedback') puts "Feedback is #{feedback}." target = status.fetch('Target') puts "Target is #{target}." new_target = target < 2048 ? 2248 : 1848 puts "Setting target to #{new_target}." jrk2cmd('--target', new_target)
