Pololu Balboa 32U4 Balancing Robot User’s Guide
Balboa 32U4 Balancing Robot with 80×10mm wheels.
1.1. Included components
1.2. What you will need
2. Contacting Pololu
3. Balboa 32U4 in detail
3.1. Microcontroller
3.2. User interface
3.3. Motors
3.4. Quadrature encoders
3.5. Inertial sensors
3.6. Power
3.7. Expansion headers
3.8. Raspberry Pi interface and level shifters
3.9. Pin assignments
3.10. Adding electronics
3.11. AVR timers
3.12. Bumper cage
3.13. Stability Conversion Kit
3.14. Schematics and dimensions
4. Assembling the Balboa 32U4 kit
5. Programming the Balboa 32U4
6. Balboa 32U4 Arduino library
7. How to make a Balboa balance
7.1. Sensor measurements
7.2. An example balancing algorithm
8. The Balboa 32U4 USB interface
9. The A-Star 32U4 Bootloader
10. Reviving an unresponsive Balboa 32U4
10.1. Reviving using the Arduino IDE
10.2. Reviving using AVRDUDE
11. Related resources
Bumper Cage Kit for Balboa
Balboa 32U4 Control Board
