Getting the prerequisites
brew install avrdude
xcode-select --install
brew tap osx-cross/avr
brew install avr-gcc
avr-gcc -v
avr-objcopy -V
make -v
avrdude
Compiling an example program
#define F_CPU 16000000
#include <avr/io.h>
#include <util/delay.h>
int main()
  DDRC |= (1 << DDC7);    // Make pin 13 be an output.
  while(1)
    PORTC |= (1 << PORTC7);   // Turn the LED on.
    _delay_ms(500);
    PORTC &= ~(1 << PORTC7);  // Turn the LED off.
    _delay_ms(500);
PORT=\\\\.\\GLOBALROOT\\Device\\USBSER000
MCU=atmega32u4
CC=avr-gcc
TARGET=main
OBJECT_FILES=main.o
all: $(TARGET).hex
clean:
	rm -f *.o *.hex *.obj *.hex
%.hex: %.obj
%.obj: $(OBJECT_FILES)
	$(CC) $(CFLAGS) $(OBJECT_FILES) $(LDFLAGS) -o $@
program: $(TARGET).hex
	avrdude -p $(MCU) -c avr109 -P $(PORT) -U flash:w:$(TARGET).hex
Make sure that the PORT variable in the Makefile is the name of the device’s virtual serial port. In Windows, \\\\.\\GLOBALROOT\\Device\\USBSER000 should work if the A-Star is the only USB device connected that is using the usbser.sys driver, but you can change it to be the actual name of the COM port (e.g. COM13).
In a command prompt, navigate to the directory with the Makefile and main.c. If you run the command make, the code should get compiled and produce a file named “main.hex”.
Programming
To program the A-Star device, you will need to get it into bootloader mode first. One way to do this is to reset the AVR twice within 750 ms. Most of the boards in our 32U4 family have a reset button that can be used to reset the board. On any of our 32U4 family of boards, a pushbutton can be connected between the GND and RST pins to serve as a reset button, or you can use a wire. Once the device is in bootloader mode, quickly run the command make program to program it. If you wait longer than 8 seconds, the A-Star bootloader will exit and the AVR will go back to running the user program.
Zumo 32U4 OLED Main Board
Zumo 32U4 Main Board v1.1
Zumo 32U4 Front Sensor Array
Zumo 32U4 Main Board v1.0
