5. Programming the Zumo 32U4
The Zumo 32U4 is designed to be programmed over USB from the Arduino IDE. It can be programmed from Windows, Linux, and macOS. The ATmega32U4 on the Zumo 32U4 comes preloaded with the same USB bootloader as the A-Star 32U4 family of general-purpose programmable ATmega32U4 boards. The following sections will help you get started programming your Zumo 32U4.
Zumo 32U4 OLED Main Board
Zumo 32U4 Main Board v1.1
Zumo 32U4 Front Sensor Array
Zumo 32U4 Main Board v1.0
