Support » Tic Stepper Motor Controller User’s Guide »
6. Setting reference
This section lists all of the settings that the Tic supports. For each setting, this section contains several pieces of information:
- The Offset of each setting is the location where it is stored in the Tic’s EEPROM memory. You can use this offset with the “Read setting” and “Set setting” commands.
- The Type of each setting specifies how many bits the setting occupies, and says whether it is signed or unsigned (if applicable). All the multi-byte settings use little-endian format, meaning that the least-significant byte comes first.
- The Data entry for each setting specifies how the data for that setting is encoded in the Tic’s memory. Some of the settings lack this field because they are simply dimensionless integers, so their encoding is straightforward.
- The Default entry for each setting is the default value it has on a new Tic or a Tic that has been reset to its defaults.
- The Range entry for each setting is the allowed range of values for the setting, if applicable. Trying to use a value outside of this range could result in unexpected behavior.
- The Settings file entry for each setting is the name of the setting in a Tic settings file, if applicable. You can save and load Tic settings files from the “File” menu of the Tic Control Center, or by using the Tic Command-line Utility (ticcmd).
- The Settings file data entry for each setting is the specification of how that setting is encoded in a settings file. Some of the settings lack this field because the encoding is straightforward.
- The Tic Control Center entry for each setting is the location of that setting in the Tic Control Center software, if applicable.
List of settings
- Control mode
- Never sleep
- Disable safe start
- Ignore ERR line high
- Automatically clear driver errors
- Soft error response
- Soft error position
- Serial baud rate / serial baud rate generator
- Serial device number
- Serial alternative device number
- Serial enable alternative device number
- Serial 14-bit device number
- Command timeout
- Serial CRC for commands
- Serial CRC for responses
- Serial 7-bit responses
- Serial response delay
- VIN measurement calibration
- Enable input averaging
- Input hysteresis
- Input scaling degree
- Invert input direction
- Input minimum
- Input neutral minimum
- Input neutral maximum
- Input maximum
- Target minimum
- Target maximum
- Encoder prescaler
- Encoder postscaler
- Enable unbounded position control
- SCL pin configuration
- SDA pin configuration
- TX pin configuration
- RX pin configuration
- RC pin configuration
- Switch polarity map
- Kill switch map
- Limit switch forward map
- Limit switch reverse map
- Current limit
- Current limit during error
- Step mode
- Decay mode (non-HP)
- Decay mode (HP)
- AGC mode (T249 only)
- AGC bottom current limit (T249 only)
- AGC current boost steps (T249 only)
- AGC frequency limit (T249 only)
- Enable unrestricted current limits (36v4 only)
- Fixed off time (36v4 only)
- Current trip blanking time (36v4 only)
- Enable adaptive blanking time (36v4 only)
- Mixed decay transition time (36v4 only)
- Max speed
- Starting speed
- Max acceleration
- Max deceleration
- Invert motor direction
- Enable automatic homing
- Automatic homing forward
- Homing speed towards
- Homing speed away
- Not initialized
Control mode
| Offset | 0x01 |
| Type | unsigned 8-bit |
| Data |
| Default | Serial / I²C / USB |
| Settings file | control_mode |
| Settings file data |
| Tic Control Center | Input and motor settings tab, Control mode |
The control mode determines what inputs the Tic will use to control the stepper motor, and whether to use position control or speed control.
Never sleep
| Offset | Bit 0 of byte 0x02 |
| Type | boolean |
| Default | false |
| Settings file | never_sleep |
| Tic Control Center | Advanced settings tab, Miscellaneous box, Never sleep |
By default, if the Tic is powered from a USB bus that is in suspend mode (e.g. the computer is sleeping) and VIN power is not present, it will go to sleep to reduce its current consumption and comply with the USB specification. If you enable the “Never sleep” option, the Tic will never go to sleep.
Disable safe start
| Offset | Bit 0 of byte 0x03 |
| Type | boolean |
| Default | false |
| Settings file | disable_safe_start |
| Tic Control Center | Advanced settings tab, Miscellaneous box, Disable safe start |
This option disables the safe start feature, which is described in Section 5.4.
| Offset | Bit 0 of byte 0x04 |
| Type | boolean |
| Default | false |
| Settings file | ignore_err_line_high |
| Tic Control Center | Advanced settings tab, Miscellaneous box, Ignore ERR line high |
This option disables the “ERR line high” error, which is described in Section 5.4.
| Offset | Bit 0 of byte 0x08 |
| Type | boolean |
| Default | true |
| Settings file | auto_clear_driver_error |
| Tic Control Center | Advanced settings tab, Miscellaneous box, Automatically clear driver errors |
When enabled, this option causes the Tic to periodically clear latched motor driver errors, as described in Section 5.4.
Soft error response
| Offset | 0x53 |
| Data |
| Default | Decelerate to hole |
| Settings file | soft_error_response |
| Settings file data | deenergize, halt_and_hold, decel_to_hold, or go_to_position |
| Tic Control Center | Advanced settings tab, Soft error response box |
This setting sets the soft error response type, as described in Section 5.4.
Soft error position
| Offset | 0x54 |
| Type | signed 32-bit |
| Data | a position in units of microsteps |
| Default | 0 |
| Range | -2,147,483,648 to 2,147,483,647 |
| Settings file | soft_error_position |
| Tic Control Center | Advanced settings tab, Soft error response box, Go to position |
If the “Soft error response” setting is set to “Go to position”, this setting determines what position the Tic will go to when a soft error happens. For more information, see Section 5.4.
| Offset | 0x05 |
| Type | unsigned 16-bit |
| Data | 12000000 bps divided by desired serial baud rate |
| Default | 9600 bps |
| Range | 200 bps to 115385 bps |
| Settings file | serial_baud_rate |
| Settings file data | Desired serial baud rate in bits per second |
| Tic Control Center | Input and motor settings tab, Serial box, Baud rate |
The serial baud rate is the speed that the Tic uses for serial communication on its RX and TX lines. The Tic software presents the baud rate as a whole number in units of bits per second (bps). The value that actually is stored in the Tic’s EEPROM memory is a 16-bit unsigned integer called the “Serial baud rate generator”, and it 12000000 bps divided by the desired baud rate, rounded to the nearest whole number.
| Offset | 0x07 and 0x69 |
| Type | unsigned 14-bit |
| Default | 14 |
| Range | 0 to 16383 |
| Settings file | serial_device_number |
| Tic Control Center | Input and motor settings tab, Serial box, Device number |
This number serves as the device number to use for Pololu Protocol serial communication and the 7-bit address to use for I²C communication.
This number is stored in two separate pieces in the settings memory: the lower 7 bits of the device number are stored in the lower 7 bits of the settings byte at offset 0x07. The upper 7 bits of the device number are stored in the lower 7 bits of the settings byte at offset 0x69.
This setting was originally a 7-bit setting stored at offset 0x07, but it was expanded to 14 bits in firmware version 1.06.
| Offset | 0x6A and 0x6B |
| Default | 0 |
| Settings file | serial_alt_device_number |
| Tic Control Center | Input and motor settings tab, Serial box, Alternative device number numeric input |
This is an alternative device number that the Tic can use for the Pololu Protocol. If the alternative device number is enabled, the Tic will respond both to it and to regular device number.
This number is stored in two separate pieces in the settings memory: the lower 7 bits of are stored in the lower 7 bits of the settings byte at offset 0x6A. The upper 7 bits are stored in the lower 7 bits of the settings byte at offset 0x6B.
This setting was added in firmware version 1.06.
| Offset | Bit 7 of byte 0x6A |
| Type | boolean |
| Default | 0 |
| Settings file | serial_enable_alt_device_number |
| Tic Control Center | Input and motor settings tab, Serial box, Alternative device number checkbox |
If this setting is set to true, the Tic will pay attention to Pololu Protocol serial commands that are addressed to the alternative device number.
Command timeout
| Offset | 0x09 |
| Data | timeout value in units of milliseconds, or 0 to disable the feature |
| Default | 1000 ms |
| Range | 0 ms to 60000 ms |
| Settings file | command_timeout |
| Tic Control Center | Input and motor settings tab, Serial box, Enable command timeout |
The “Command timeout” setting is the time in milliseconds before the Tic considers it an error if it has not received certain commands. See the description of the “Command timeout” error in Section 5.4.
| Offset | Bit 3 of byte 0x0B |
| Type | boolean |
| Default | false |
| Settings file | serial_14bit_device_number |
| Tic Control Center | Input and motor settings tab, Serial box, Enable 14-bit device number |
If this setting is enabled, the Tic will expect two device number bytes in serial commands using the Pololu Protocol, and the maximum device number changes from 127 to 16383. See Section 9 for details about the Pololu Protocol.
| Offset | Bit 0 of byte 0x0B |
| Type | boolean |
| Default | false |
| Settings file | serial_crc_for_commands |
| Tic Control Center | Input and motor settings tab, Serial box, Enable CRC for commands |
With this option enabled, the Tic requires a 7-bit CRC byte to be appended to every serial command, as described in Section 9.
This setting was previously named “Serial CRC enabled” and stored in the settings file as serial_crc_enabled.
| Offset | Bit 1 of byte 0x0B |
| Type | boolean |
| Default | false |
| Settings file | serial_crc_for_responses |
| Tic Control Center | Input and motor settings tab, Serial box, Enable CRC for responses |
With this option enabled, the Tic appends a 7-bit CRC byte to every response it sends (unless the response is longer than 14 bytes), as described in Section 9.
| Offset | Bit 2 of byte 0x0B |
| Type | boolean |
| Default | false |
| Settings file | serial_7bit_responses |
| Tic Control Center | Input and motor settings tab, Serial box, Enable 7-bit responses |
With this option enabled, the Tic encodes its serial responses using bytes between 0 and 0x7F, as described in Section 9. This can be useful in setups where the serial response from one Tic will be seen by other Tic devices.
| Offset | 0x5E |
| Data | time in units of microseconds |
| Default | 0 |
| Range | 0 to 255 |
| Settings file | serial_response_delay |
| Tic Control Center | Input and motor settings, Serial box, Response delay |
This setting specifies the minimum amount of time to wait, in microseconds, before processing an I²C byte or sending a serial response. This setting was added in firmware version 1.02.
| Offset | 0x14 |
| Type | signed 16-bit |
| Default | 0 |
| Range | −500 to +500 |
| Settings file | vin_calibration |
| Tic Control Center | Advanced settings tab, Miscellaneous box, VIN measurement calibration |
This setting adjusts the scaling of the Tic’s VIN measurements. If the Tic’s VIN readings are lower than the actual VIN voltage, you can use a positive value to scale the readings up. If the readings are high, you can use a negative value to scale the readings down. On the Tic T500 and Tic T825, a value of 33 corresponds to a 4% change. On the Tic T834, a value of 9 corresponds to a 4% change. On the Tic T249 and Tic 36v4, a value of 21 corresponds to a 4% change.
| Offset | Bit 0 of 0x2E |
| Type | boolean |
| Default | true |
| Settings file | input_averaging_enabled |
| Tic Control Center | Input and motor settings tab, Input conditioning box, Enable input averaging |
This setting enables RC/analog input averaging as described in Section 5.2.
Input hysteresis
| Offset | 0x2F |
| Default | 0 |
| Range | 0 to 65535 |
| Settings file | input_hysteresis |
| Tic Control Center | Input and motor settings tab, Input conditioning box, Input hysteresis |
This setting specifies the amount of hysteresis to apply to RC/analog inputs, as described in Section 5.2.
| Offset | 0x20 |
| Data |
| Default | linear |
| Settings file | input_scaling_degree |
| Settings file data | linear, quadratic, or cubic |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Scaling degree |
By default, the scaling function used to convert RC and analog inputs into a speed or position is linear. If you set the scaling degree to quadratic or cubic, then the Tic uses a higher-degree polynomial function to scale its RC or analog inputs, which can give you finer control when the input is closer to its neutral position. For more information, see Section 5.2.
| Offset | 0x21 |
| Data |
| Default | false |
| Settings file | input_invert |
| Settings file data | false or true |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Invert input direction |
By default, lower analog voltages and shorter RC pulse widths correspond to negative positions and speeds. When enabled, this setting flips that correspondence, as described in Section 5.2.
Input minimum
| Offset | 0x22 |
| Default | 0 |
| Range | 0 to 4095 |
| Settings file | input_min |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Input column, Minimum |
This is one of the RC/analog input scaling parameters described in Section 5.2.
| Offset | 0x24 |
| Default | 2015 |
| Range | 0 to 4095 |
| Settings file | input_neutral_min |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Input column, Neutral min |
| Offset | 0x26 |
| Default | 2080 |
| Range | 0 to 4095 |
| Settings file | input_neutral_max |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Input column, Neutral max |
Input maximum
| Offset | 0x28 |
| Default | 4095 |
| Range | 0 to 4095 |
| Settings file | input_max |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Input column, Maximum |
Target minimum
| Offset | 0x2A |
| Default | −200 |
| Range | −2,147,483,647 to 0 |
| Settings file | output_min |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Target column, Minimum |
Target maximum
| Offset | 0x32 |
| Default | 200 |
| Range | 0 to 2,147,483,647 |
| Settings file | output_max |
| Tic Control Center | Input and motor settings tab, RC and analog scaling box, Target column, Maximum |
Encoder prescaler
| Offset | 0x58 |
| Type | unsigned 32-bit |
| Default | 1 |
| Range | 1 to 2,147,483,647 |
| Settings file | encoder_prescaler |
| Tic Control Center | Input and motor settings tab, Encoder box, Prescaler |
For encoder control modes, this determines the number of encoder counts per unit change of the stepper motor position or speed, as described in Section 5.3.
Encoder postscaler
| Offset | 0x37 |
| Default | 1 |
| Settings file | encoder_postscaler |
| Tic Control Center | Input and motor settings tab, Encoder box, Postscaler |
For encoder control modes, this determines the size of a unit change in the stepper motor position or speed, as described in Section 5.3.
| Offset | 0x5C |
| Data |
| Default | false |
| Settings file | encoder_unlimited |
| Tic Control Center | Input and motor settings tab, Encoder box, Enable unbounded position control |
This setting is described in Section 5.3.
| Offset | 0x3B |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | scl_config |
| Settings file data | Space-separated list including a subset of pin options (pullup, analog, and active_high) and one pin function: default, user_io, user_input, pot_power, serial (SCL), or kill_switch. |
| Tic Control Center | Advanced settings tab, Pin configuration box, SCL |
This byte contains most of the configuration of the SCL pin, as described in Section 5.5.
If the pin function is set to “Default”, then the Tic will ignore all of the options set in this byte and just use default settings. The default settings for SCL depend on the control mode: in an analog control mode, SCL is configured as a potentiometer power pin, while in all other control modes, the SCL pin is used as the I²C clock line with its internal pull-up enabled.
| Offset | 0x3C |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | sda_config |
| Settings file data | Space-separated list including a subset of pin options (pullup, analog, and active_high) and one pin function: default, user_io, user_input, serial (SDA), or kill_switch. |
| Tic Control Center | Advanced settings tab, Pin configuration box, SDA |
This byte contains most of the configuration of the SDA pin, as described in Section 5.5.
If the pin function is set to “Default”, then the Tic will ignore all of the options set in this byte and just use default settings. The default settings for SDA depend on the control mode: in an analog control mode, SDA is configured as a user input with analog readings enabled, while in all other control modes, SDA is used as the I²C data line with its internal pull-up enabled.
| Offset | 0x3D |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | tx_config |
| Settings file data | Space-separated list including a subset of pin options (analog and active_high) and one pin function: default, user_io, user_input, serial (TX), encoder, or kill_switch. |
| Tic Control Center | Advanced settings tab, Pin configuration box, TX |
This byte contains most of the configuration of the TX pin, as described in Section 5.5.
If the pin function is set to “Default”, then the Tic will ignore all of the options set in this byte and just use default settings. The default settings for TX depend on the control mode: in an encoder control mode, TX is configured as an encoder input, while in all other control modes, TX is used as the serial transmit line.
| Offset | 0x3E |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | rx_config |
| Settings file data | Space-separated list including a subset of pin options (analog and active_high) and one pin function: default, user_io, user_input, serial (RX), encoder, or kill_switch. |
| Tic Control Center | Advanced settings tab, Pin configuration box, RX |
This byte contains most of the configuration of the RX pin, as described in Section 5.5.
If the pin function is set to “Default”, then the Tic will ignore all of the options set in this byte and just use default settings. The default settings for RX depend on the control mode: in an encoder control mode, RX is configured as an encoder input, while in all other control modes, RX is used as the serial receive line.
| Offset | 0x3F |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | rc_config |
| Settings file data | Space-separated list including a subset of pin options (active_high or nothing) and one pin function: default, user_input, rc, or kill_switch. |
| Tic Control Center | Advanced settings tab, Pin configuration box, RC |
This byte contains most of the configuration of the RC pin, as described in Section 5.5.
If the pin function is set to “Default”, then the Tic will use the RC pin as an RC pulse input and measure the durations of pulses received on the line.
Switch polarity map
| Offset | 0x36 |
| Type | 8-bit |
| Data |
| Default | 0 |
| Settings file | Listed in scl_config, sda_config, tx_config, rx_config, rc_config |
| Settings file data | active_high or nothing |
| Tic Control Center | Advanced settings tab, Pin configuration, Active high checkboxes |
For each pin configured as a switch, this setting allows you to choose whether that pin is active high or active low. If the pin’s switch polarity bit is 0, it is active low (a low voltage corresponds to an active switch). If the bit is 1, it is active high.
Kill switch map
| Offset | 0x5D |
| Type | 8-bit |
| Data |
| Default | 0 |
This byte contains redundant information to make the firmware implementation simpler. Each of the five input pins of the Tic has one bit in this byte. If the bit is 0, it means that the pin is not a kill switch. If the bit is 1, it means that the pin is a kill switch.
| Offset | 0x5F |
| Type | 8-bit |
| Data |
| Default | 0 |
| Offset | 0x60 |
| Type | 8-bit |
| Data |
| Default | 0 |
Current limit
| Offset | 0x40 |
| Data |
| Default |
| Range |
| Settings file | current_limit |
| Settings file data | current limit, in units of mA |
| Tic Control Center | Input and motor settings, Motor box, Current limit |
This setting determines how much current the Tic’s motor driver will attempt to generate in the stepper motor coils. For general information about the current limit, see Section 4.3.
Note that this setting just sets the default current limit, and it can be temporarily overridden using the “Set current limit” command.
The Tic T500 represents current limits using codes between 0 and 32. The table below shows the correspondence between these current limit codes and the nominal current limit.
| Current limit code | Tic T500 current limit |
| 0 | 0 mA |
| 1 | 1 mA |
| 2 | 174 mA |
| 3 | 343 mA |
| 4 | 495 mA |
| 5 | 634 mA |
| 6 | 762 mA |
| 7 | 880 mA |
| 8 | 990 mA |
| 9 | 1092 mA |
| 10 | 1189 mA |
| 11 | 1281 mA |
| 12 | 1368 mA |
| 13 | 1452 mA |
| 14 | 1532 mA |
| 15 | 1611 mA |
| 16 | 1687 mA |
| 17 | 1762 mA |
| 18 | 1835 mA |
| 19 | 1909 mA |
| 20 | 1982 mA |
| 21 | 2056 mA |
| 22 | 2131 mA |
| 23 | 2207 mA |
| 24 | 2285 mA |
| 25 | 2366 mA |
| 26 | 2451 mA |
| 27 | 2540 mA |
| 28 | 2634 mA |
| 29 | 2734 mA |
| 30 | 2843 mA |
| 31 | 2962 mA |
| 32 | 3093 mA |
The Tic T834, Tic T825, and Tic T249 represent current limits using numbers between 0 and 124 that are linearly proportional to the current limit. However, due to hardware limitations, not all of these current limits are actually achievable. Disregarding the maximum allowed current limits documented above, the achievable current limits are as follows: 0 through 31, even numbers from 32 to 62, and multiples of four from 64 to 124. If you set a current limit that is not achievable, the Tic will generally accept it and store it in the “Current limit” variable, but it will actually have the same effect as the highest achievable current limit lower than it. For example, a current limit of 33 is the same as a current limit of 32, and a current limit of 66 is the same as a current limit of 64.
The Tic 36v4 represents current limits using numbers between 0 and 127 that are linearly proportional to the current limit. All numbers within this range are valid current limits.
Tic 36v4 warning: The Tic 36v4 has no meaningful over-temperature shut-off (while the gate driver IC has over-temperature protection, it is the external MOSFETs that will overheat first). An over-temperature condition can cause permanent damage to the motor driver. We strongly recommend you do not increase the current limit setting beyond 4000 mA (or lower in applications with reduced heat dissipation) unless you can first confirm that the temperature of the MOSFETs will stay under 140°C. By default, the Tic will prevent you from setting a current limit above 4000 mA, but you can override this using the Enable unrestricted current limits setting.
| Offset | 0x31 |
| Data | current limit code as specified above for the normal current limit setting, or 0xFF to disable the feature |
| Default | 0 |
| Range | between 0 mA and the normal current limit setting, or disabled |
| Settings file | current_limit_during_error |
| Settings file data | current limit, in units of mA, or -1 to disable the feature |
| Tic Control Center | Advanced settings tab, Soft error response, Use different current limit during soft error |
If enabled, this setting causes the Tic to use a different stepper motor current limit instead of the normal current limit if an error is happening and the driver is enabled. See Section 5.4.
Step mode
| Offset | 0x41 |
| Data |
| Default | Full step |
| Settings file | step_mode |
| Settings file data | 1, 2, 2_100p, 4, 8, 16, 32, 64, 128, 256, full, or half |
| Tic Control Center | Input and motor settings tab, Motor box, Step mode |
The step mode setting determines how many microsteps add up to one full step. More information about the step modes can be found in Section 4.3.
The different Tic models have different available step modes:
- The Tic T500 only supports full, 1/2, 1/4, and 1/8 step modes.
- The Tic T825 Tic T834, and Tic T249 support full, 1/2, 1/4, 1/8, 1/16, and 1/32 step modes.
- The Tic T249 supports “Full step 100%” mode instead of normal full step mode, and it additionally supports “1/2 step 100%” mode. In these two “100%” modes, any non-zero coil current is 100% of the rated current instead of 70% (as in the normal full and 1/2 step modes). These modes are sometimes described as “non-circular”.
- The Tic 36v4 supports full, 1/2, 1/4, 1/8, 1/16, 1/32, 1/64, 1/128, and 1/256 step modes.
Note that this setting just sets the default step mode, and it can be temporarily overridden using the “Set step mode” command.
Decay mode (non-HP)
| Offset | 0x42 |
| Data |
| Default | 0 |
| Settings file | decay_mode |
| Settings file data | mixed, slow, fast, mixed25, mixed50, or mixed75 |
| Tic Control Center | Input and motor settings tab, Motor box, Decay mode |
This setting does not apply to the Tic 36v4. For that Tic, see Decay mode (HP) instead.
More information about the Tic T500 automatic decay mode selection can be found in the MP6500 datasheet (1MB pdf) and Section 4.3.
More information about the Tic T249’s Advanced Dynamic Mixed Decay (ADMD) can be found in the TB67S249FTG datasheet (533k pdf) and Section 4.3.
More information about the Tic T825 decay modes can be found in the DRV8825 datasheet (1k redirect) and Section 4.3.
More information about the Tic T834 decay modes can be found in the DRV8834 datasheet (1k redirect) and Section 4.3.
Note that this setting just sets the default decay mode, and it can be temporarily overridden using the “Set decay mode” command.
Decay mode (HP)
| Data |
| Default | Auto mixed |
| Settings file | hp_decmod |
| Settings file data | slow, slow_mixed, fast, mixed, slow_auto_mixed, auto_mixed |
This setting only applies to the Tic 36v4. For other Tic boards, see Decay mode (non-HP).
More information about the Tic 36v4 decay modes can be found in the DRV8711 datasheet (1k redirect) and Section 4.3.
AGC mode
| Offset | 0x6C |
| Data |
| Default | Off |
| Settings file | agc_mode |
| Settings file data | off, on, or active_off |
| Tic Control Center | Input and motor settings tab, Motor box, AGC mode |
This setting only applies to the Tic T249. It controls whether the Active Gain Control (AGC) feature is enabled or not. The three options are:
- Off: AGC is disabled.
- On: AGC is enabled.
- Active off: AGC is disabled, but if you are using full-step mode (i.e. not using microstepping), the driver inserts a period of time for each coil where the coil’s current is zero, just like it would do if AGC were enabled.
More information about these AGC modes can be found in the TB67S249FTG application note (1MB pdf).
Note that this setting just sets the default AGC mode, and it can be temporarily overridden using the “Set AGC option” command.
| Offset | 0x6D |
| Data |
| Default | 80% |
| Settings file | agc_bottom_current_limit |
| Settings file data | 45, 50, 55, 60, 65, 70, 75, or 80 |
| Tic Control Center | Input and motor settings tab, Motor box, AGC bottom current limit |
This setting only applies to the Tic T249. It controls how much the Active Gain Control (AGC) can reduce the coil current when a light load on the motor is detected. With the default value of 80%, the AGC will only reduce the current limit down to 80% of the configured current limit. You can find more information about this setting in the TB67S249FTG datasheet (533k pdf).
Note that this setting just sets the default bottom current limit, and it can be temporarily overridden using the “Set AGC option” command.
| Offset | 0x6E |
| Data |
| Default | 5 steps |
| Settings file | agc_current_boost_steps |
| Settings file data | 5, 7, 9, or 11 |
| Tic Control Center | Input and motor settings tab, Motor box, AGC current boost steps |
This setting only applies to the Tic T249. It controls how long the Active Gain Control (AGC) takes to increase the current in the coils when a heavy load on the motor is detected. With the default value of 5 steps, the AGC will increase the current in 5 steps, which is the quickest option available. You can find more information about this setting in the TB67S249FTG datasheet (533k pdf).
Note that this setting just sets the default number of steps, and it can be temporarily overridden using the “Set AGC option” command.
AGC frequency limit
| Offset | 0x6F |
| Data |
| Default | Off |
| Settings file | agc_frequency_limit |
| Settings file data | off, 225, 450, or 675 |
| Tic Control Center | Input and motor settings, Motor box, AGC frequency limit |
This setting only applies to the Tic T249. It controls the frequency limit feature provided by the TB67S249FTG driver, which can optionally prevent the the Active Gain Control (AGC) from lowering the coil current if the stepping frequency is too low. The default value of “Off” disables this feature. The other values specify a lower limit on the frequency of full steps.
For example, if this setting is 225 Hz, then the AGC will not activate unless the rate of full steps is at least 225 Hz. If you are using 1/4 microstepping, this corresponds to a microstep frequency of 900 Hz, which corresponds to a speed of approximately 9,000,000.
Note that this setting just sets the default AGC frequency limit, and it can be temporarily overridden using the “Set AGC option” command.
| Offset | Bit 0 of 0x6C |
| Type | boolean |
| Default | false |
| Settings file | hp_enable_unrestricted_current_limits |
| Tic Control Center | Input and motor settings tab, Motor box, Enable adaptive blanking time |
By default, the Tic 36v4 caps its current limit at 3939 mA (which is encoded as 55). Any attempt to set a current limit above that, whether from a setting or a command, results in 3939 mA. If this setting is enabled, that limit is disabled, and currents can go all the way up to 9095 mA (encoded as 127). Please read the warning below if you are considering enabling this setting.
Fixed off time
| Default | 25.5 μs |
| Range | 0.5 μs to 128.0 μs, 0.5 μs increments |
| Settings file | hp_toff |
| Tic Control Center | Input and motor settings tab, Motor box, Fixed off time |
This setting only applies to the Tic 36v4. The driver uses PWM current regulation to limit the motor coil current; at the start of each PWM cycle, the H-bridge is enabled and current starts increasing through the motor coil. Once the current reaches the limit (chopping threshold), the H-bridge is disabled and the current is allowed to decay for a fixed period, which is determined by this parameter. Decreasing the fixed off time increases the PWM frequency, which can reduce current ripple, but it also increases heat from switching losses. If the fixed off time is too short or too long for the selected decay mode, current waveform distortion can occur.
You can find more information about this setting in the DRV8711 datasheet (1k redirect). The DRV8711 Decay Mode Setting Optimization Guide (1k redirect) shows how changing this parameter can help improve current waveforms.
| Default | 1.00 μs |
| Range | 1.00 μs to 5.10 μs, 0.02 μs increments |
| Settings file | hp_tblank |
| Tic Control Center | Input and motor settings tab, Motor box, Current trip blanking time |
This setting only applies to the Tic 36v4. It determines the minimum on time for each PWM cycle. You can find more information about this setting in the DRV8711 datasheet (1k redirect).
| Type | boolean |
| Default | true |
| Settings file | hp_abt |
This setting only applies to the Tic 36v4. If enabled, it causes the driver to cut the blanking time in half for low current steps, which can help improve current control accuracy. You can find more information about this setting in the DRV8711 datasheet (1k redirect).
| Default | 8.0 μs |
| Range | 0.0 μs to 127.5 μs, 0.5 μs increments |
| Settings file | hp_tdecay |
| Tic Control Center | Input and motor settings tab, Motor box, Mixed decay transition time |
This setting only applies to the Tic 36v4. When the driver is configured to use mixed decay, it begins by using fast decay but transitions to slow decay after a fixed period, which is determined by this parameter. You can find more information about this setting in the DRV8711 datasheet (1k redirect) and the DRV8711 Decay Mode Setting Optimization Guide (1k redirect).
Max speed
| Offset | 0x47 |
| Data | speed in units of pulses per 10,000 seconds |
| Default | 2,000,000 (200 pulses/s) |
| Range | 0 to 500,000,000 (50,000 pulses/s) |
| Settings file | max_speed |
| Tic Control Center | Input and motor settings, Motor box, Max speed |
The “Max speed” setting is the upper limit on how fast the Tic will try to drive the stepper motor. For more information, see Section 5.1.
Note that this setting just sets the default value for the “Max speed” motion parameter, and it can be temporarily overridden using the “Set max speed” command.
Starting speed
| Offset | 0x43 |
| Default | 0 |
| Settings file | starting_speed |
| Tic Control Center | Input and motor settings, Motor box, Starting speed |
The “Starting speed” is the maximum speed at which instant acceleration and deceleration are allowed. For more information, see Section 5.1.
Note that this setting just sets the default value for the “Starting speed” motion parameter, and it can be temporarily overridden using the “Set starting speed” command.
Max acceleration
| Offset | 0x4F |
| Data | acceleration in units of pulses per second per 100 seconds |
| Default | 40,000 |
| Range | 100 to 2,147,483,647 |
| Settings file | max_accel |
| Tic Control Center | Input and motor settings tab, Motor box, Max acceleration |
The “Max acceleration” setting specifies how rapidly the speed is allowed to increase. For more information, see Section 5.1.
Note that this setting just sets the default value for the “Max acceleration” motion parameter, and it can be temporarily overridden using the “Set max acceleration” command.
Max deceleration
| Offset | 0x4B |
| Data | deceleration in units of pulses per second per 100 seconds, or 0 to make it the same as the max acceleration |
| Default | 0 |
| Settings file | max_decel |
| Tic Control Center | Input and motor settings tab, Motor box, Max deceleration |
The “Max deceleration” setting specifies how rapidly the speed is allowed to decrease. For more information, see Section 5.1.
Note that this setting just sets the default value for the “Max deceleration” motion parameter, and it can be temporarily overridden using the “Set max deceleration” command. Also, even if this setting is 0 (which corresponds to checking the “Use max acceleration limit for deceleration” box in the Tic Control Center), the “Set max acceleration” command will only change the max acceleration without changing the max deceleration.
| Offset | Bit 0 of 0x1B |
| Type | boolean |
| Default | false |
| Settings file | invert_motor_direction |
| Tic Control Center | Input and motor settings tab, Motor box, Invert motor direction |
By default, an increasing position or a positive speed corresponds to taking steps forward through the motor driver’s current indexer table, so the amount of current flowing from B1 to B2 lags behind the amount of current flowing from A1 to A2. This setting flips that correspondence if it is enabled, making the motor turn in the opposite direction. See Section 5.1.
| Offset | Bit 1 of byte 0x02 |
| Type | boolean |
| Default | false |
| Settings file | auto_homing |
| Tic Control Center | Advanced settings tab, Homing box, Enable automatic homing |
If true, the Tic will start the homing procedure automatically whenever the “Position uncertain” flag is set, the “Operation state” is “Normal”, and the “Input state” variable (which is set either by the control mode or by serial commands) is “Target position”. This setting is mainly intended for use with “RC Position”, “Analog position”, and “Encoder position” control modes. See Section 5.6 for more information about homing.
| Offset | Bit 2 of byte 0x02 |
| Type | boolean |
| Default | false |
| Settings file | auto_homing_forward |
| Tic Control Center | Advanced settings tab, Homing box, Automatic homing direction |
If true, the Tic’s automatic homing feature will perform homing in the forward direction. If false, the automatic homing feature will perform homing in the reverse direction.
| Offset | 0x61 |
| Default | 1000000 (100 pulses/s) |
| Settings file | homing_speed_towards |
| Tic Control Center | Advanced settings tab, Homing box, Homing speed towards |
This is the speed that the Tic uses during the homing procedure when it is travelling towards the limit switch. See Section 5.6.
Homing speed away
| Offset | 0x65 |
| Settings file | homing_speed_away |
| Tic Control Center | Advanced settings tab, Homing box, Homing speed away |
This is the speed that the Tic uses briefly during the homing procedure when it is travelling away from the limit switch to deactivate it. See Section 5.6.
Not initialized
| Offset | 0x00 |
| Data |
| Default | false |
This special setting keeps track of whether the rest of the settings have been initialized or not. Normally it is zero, which means false. If you set it to a non-zero value, then the Tic will reset all of the settings to their default values the next time the Tic is reset or reinitialized. This is how the “Restore default settings” command in the Tic Control Center and the --restore-defaults option in the command-line utility are implemented.
