12.8. Example I²C code for Linux in C
The example C code below uses the I²C API provided by the Linux kernel to send and receive data from a Tic. It demonstrates how to set the target position of the Tic and how to read variables from it. This code only works on Linux.
If you are using a Raspberry Pi, please note that the Raspberry Pi’s hardware I²C module has a bug that causes this code to not work reliably. As a workaround, we recommend enabling the i2c-gpio overlay and using the I²C device that it provides. To do this, add the line dtoverlay=i2c-gpio to /boot/config.txt and reboot. The overlay documentation has information about the parameters you can put on that line, but those parameters are not required. Connect the Tic’s SDA line to GPIO23 and connect the Tic’s SCL line to GPIO24. The i2c-gpio overlay creates a new I²C device which is usually named /dev/i2c-3, and the code below uses that device. To give your user permission to access I²C busses without being root, you might have to add yourself to the i2c group by running sudo usermod -a -G i2c $(whoami) and restarting.
You might notice that the Tic only performs the desired movement for about a second before it stops moving and the red LED turns on, indicating an error. This is because of the Tic’s command timeout feature: by default, the Tic’s “Command timeout” error will happen if it does not receive certain commands periodically (see Section 5.4 for details), causing the motor to stop. You can send a “Reset command timeout” command every second to get around this, or you can disable the command timeout feature using the Tic Control Center: uncheck the “Enable command timeout” checkbox in the “Serial” box.
// Uses the Linux I2C API to send and receive data from a Tic.
// NOTE: The Tic's control mode must be "Serial / I2C / USB".
// NOTE: For reliable operation on a Raspberry Pi, enable the i2c-gpio
//   overlay and use the I2C device it provides (usually /dev/i2c-3).
// NOTE: You might need to change the 'const char * device' line below
//   to specify the correct I2C device.
// NOTE: You might need to change the `const uint8_t address' line below
// to match the device number of your Tic.
#include <fcntl.h>
#include <linux/i2c.h>
#include <linux/i2c-dev.h>
#include <stdint.h>
#include <stdio.h>
#include <sys/ioctl.h>
#include <unistd.h>
// Opens the specified I2C device.  Returns a non-negative file descriptor
// on success, or -1 on failure.
int open_i2c_device(const char * device)
  int fd = open(device, O_RDWR);
  if (fd == -1)
    perror(device);
    return -1;
  return fd;
// Sends the "Exit safe start" command.
// Returns 0 on success and -1 on failure.
int tic_exit_safe_start(int fd, uint8_t address)
  uint8_t command[] = { 0x83 };
  struct i2c_msg message = { address, 0, sizeof(command), command };
  struct i2c_rdwr_ioctl_data ioctl_data = { &message, 1 };
  int result = ioctl(fd, I2C_RDWR, &ioctl_data);
  if (result != 1)
    perror("failed to exit safe start");
    return -1;
  return 0;
// Sets the target position, returning 0 on success and -1 on failure.
// For more information about what this command does, see the
// "Set Target Position" command in the "Command reference" section of the
// Tic user's guide.
int tic_set_target_position(int fd, uint8_t address, int32_t target)
    0xE0,
    (uint8_t)(target >> 0  & 0xFF),
    (uint8_t)(target >> 8  & 0xFF),
    (uint8_t)(target >> 16 & 0xFF),
    (uint8_t)(target >> 24 & 0xFF),
  if (result != 1)
    perror("failed to set target position");
    return -1;
  return 0;
// Gets one or more variables from the Tic (without clearing them).
// Returns 0 for success, -1 for failure.
int tic_get_variable(int fd, uint8_t address, uint8_t offset,
  uint8_t * buffer, uint8_t length)
  uint8_t command[] = { 0xA1, offset };
  struct i2c_msg messages[] = {
    { address, 0, sizeof(command), command },
    { address, I2C_M_RD, length, buffer },
  struct i2c_rdwr_ioctl_data ioctl_data = { messages, 2 };
  if (result != 2)
    perror("failed to get variables");
    return -1;
  return 0;
// Gets the "Current position" variable from the Tic.
int tic_get_current_position(int fd, uint8_t address, int32_t * output)
  *output = 0;
  uint8_t buffer[4];
  int result = tic_get_variable(fd, address, 0x22, buffer, sizeof(buffer));
  if (result) { return -1; }
  *output = buffer[0] + ((uint32_t)buffer[1] << 8) +
    ((uint32_t)buffer[2] << 16) + ((uint32_t)buffer[3] << 24);
  return 0;
int main()
  // Choose the I2C device.
  const char * device = "/dev/i2c-3";
  // Set the I2C address of the Tic (the device number).
  const uint8_t address = 14;
  int fd = open_i2c_device(device);
  if (fd < 0) { return 1; }
  int result;
  int32_t position;
  result = tic_get_current_position(fd, address, &position);
  if (result) { return 1; }
  printf("Current position is %d.\n", position);
  int32_t new_target = position > 0 ? -200 : 200;
  printf("Setting target position to %d.\n", new_target);
  result = tic_exit_safe_start(fd, address);
  result = tic_set_target_position(fd, address, new_target);
  close(fd);
  return 0;
Tic Stepper Motor Controllers
