12.5. Example serial code for Linux and macOS in C
The example C code below uses parts of the POSIX API provided by Linux and macOS to communicate with a Tic via serial. It demonstrates how to set the target position of the Tic and how to read variables from it. For a very similar example that works on Windows, see Section 12.6.
To use this code, you will need to connect the Tic’s TX, RX, and GND pins to a serial port on your computer or a USB-to-serial adapter as described in Section 4.5.
The Tic’s control mode should be set to “Serial / I²C / USB”.
You will need to change the const char * device line in the code in order to specify the correct serial port. The correct serial port name to use depends on your operating system and what type of serial port or USB-to-serial adapter you are using between the Tic and your computer.
The baud rate you select in the code should match the baud rate specified in the serial settings in the Tic Control Center. The code below uses 9600 baud, but you can easily change it to use any of the following standard baud rates: 4800, 9600, 19200, 38400, or 115200. Due to hardware limitations, the Tic cannot exactly produce 38400 baud or 115200 baud, but it can use similar baud rates that are close enough to work.
You might notice that the Tic only performs the desired movement for about a second before it stops moving and the red LED turns on, indicating an error. This is because of the Tic’s command timeout feature: by default, the Tic’s “Command timeout” error will happen if it does not receive certain commands periodically (see Section 5.4 for details), causing the motor to stop. You can send a “Reset command timeout” command every second to get around this, or you can disable the command timeout feature using the Tic Control Center: uncheck the “Enable command timeout” checkbox in the “Serial” box.
// Uses POSIX serial port functions to send and receive data from a Tic.
// NOTE: The Tic's control mode must be "Serial / I2C / USB".
// NOTE: You will need to change the 'const char * device' line below to
// specify the correct serial port.
#include <fcntl.h>
#include <stdio.h>
#include <unistd.h>
#include <stdint.h>
#include <termios.h>
// Opens the specified serial port, sets it up for binary communication,
// configures its read timeouts, and sets its baud rate.
// Returns a non-negative file descriptor on success, or -1 on failure.
int open_serial_port(const char * device, uint32_t baud_rate)
int fd = open(device, O_RDWR | O_NOCTTY);
if (fd == -1)
perror(device);
return -1;
// Flush away any bytes previously read or written.
int result = tcflush(fd, TCIOFLUSH);
if (result)
perror("tcflush failed"); // just a warning, not a fatal error
// Get the current configuration of the serial port.
struct termios options;
result = tcgetattr(fd, &options);
if (result)
perror("tcgetattr failed");
close(fd);
return -1;
// Turn off any options that might interfere with our ability to send and
// receive raw binary bytes.
options.c_iflag &= ~(INLCR | IGNCR | ICRNL | IXON | IXOFF);
options.c_oflag &= ~(ONLCR | OCRNL);
options.c_lflag &= ~(ECHO | ECHONL | ICANON | ISIG | IEXTEN);
// Set up timeouts: Calls to read() will return as soon as there is
// at least one byte available or when 100 ms has passed.
options.c_cc[VTIME] = 1;
options.c_cc[VMIN] = 0;
// This code only supports certain standard baud rates. Supporting
// non-standard baud rates should be possible but takes more work.
switch (baud_rate)
case 4800: cfsetospeed(&options, B4800); break;
case 9600: cfsetospeed(&options, B9600); break;
case 19200: cfsetospeed(&options, B19200); break;
case 38400: cfsetospeed(&options, B38400); break;
case 115200: cfsetospeed(&options, B115200); break;
default:
fprintf(stderr, "warning: baud rate %u is not supported, using 9600.\n",
baud_rate);
break;
cfsetispeed(&options, cfgetospeed(&options));
result = tcsetattr(fd, TCSANOW, &options);
if (result)
perror("tcsetattr failed");
close(fd);
return -1;
return fd;
// Writes bytes to the serial port, returning 0 on success and -1 on failure.
int write_port(int fd, uint8_t * buffer, size_t size)
ssize_t result = write(fd, buffer, size);
if (result != (ssize_t)size)
perror("failed to write to port");
return -1;
return 0;
// Reads bytes from the serial port.
// Returns after all the desired bytes have been read, or if there is a
// timeout or other error.
// Returns the number of bytes successfully read into the buffer, or -1 if
// there was an error reading.
ssize_t read_port(int fd, uint8_t * buffer, size_t size)
size_t received = 0;
while (received < size)
ssize_t r = read(fd, buffer + received, size - received);
if (r < 0)
perror("failed to read from port");
return -1;
if (r == 0)
// Timeout
break;
received += r;
return received;
// Sends the "Exit safe start" command.
// Returns 0 on success and -1 on failure.
int tic_exit_safe_start(int fd)
uint8_t command[] = { 0x83 };
return write_port(fd, command, sizeof(command));
// Sets the target position, returning 0 on success and -1 on failure.
// For more information about what this command does, see the
// "Set target position" command in the "Command reference" section of the
// Tic user's guide.
int tic_set_target_position(int fd, int32_t target)
uint32_t value = target;
uint8_t command[6];
command[0] = 0xE0;
command[1] = ((value >> 7) & 1) |
((value >> 14) & 2) |
((value >> 21) & 4) |
((value >> 28) & 8);
command[2] = value >> 0 & 0x7F;
command[3] = value >> 8 & 0x7F;
command[4] = value >> 16 & 0x7F;
command[5] = value >> 24 & 0x7F;
// Gets one or more variables from the Tic.
// Returns 0 for success, -1 for failure.
int tic_get_variable(int fd, uint8_t offset, uint8_t * buffer, uint8_t length)
uint8_t command[] = { 0xA1, offset, length };
int result = write_port(fd, command, sizeof(command));
if (result) { return -1; }
ssize_t received = read_port(fd, buffer, length);
if (received < 0) { return -1; }
if (received != length)
fprintf(stderr, "read timeout: expected %u bytes, got %zu\n",
length, received);
return -1;
return 0;
// Gets the "Current position" variable from the Tic.
int tic_get_current_position(int fd, int32_t * output)
*output = 0;
uint8_t buffer[4];
int result = tic_get_variable(fd, 0x22, buffer, sizeof(buffer));
*output = buffer[0] + ((uint32_t)buffer[1] << 8) +
((uint32_t)buffer[2] << 16) + ((uint32_t)buffer[3] << 24);
return 0;
int main()
// Choose the serial port name.
const char * device = "/dev/ttyACM0";
// Choose the baud rate (bits per second). This must match the baud rate in
// the Tic's serial settings.
uint32_t baud_rate = 9600;
int fd = open_serial_port(device, baud_rate);
if (fd < 0) { return 1; }
int result;
int32_t position;
result = tic_get_current_position(fd, &position);
if (result) { return 1; }
printf("Current position is %d.\n", position);
int32_t new_target = position > 0 ? -200 : 200;
printf("Setting target position to %d.\n", new_target);
result = tic_exit_safe_start(fd);
result = tic_set_target_position(fd, new_target);
close(fd);
return 0;
