12.10. Example I²C code for MicroPython
The example Python code below uses the machine.I2C class in MicroPython to send and receive data from a Tic via I²C. It demonstrates how to set the target position of the Tic and how to read variables from it. This example is designed to run on the Raspberry Pi Pico and can be ported to other boards by changing the line at the top that sets up the i2c object.
from machine import I2C, Pin
i2c = I2C(0, sda=Pin(8), scl=Pin(9), freq=400000)
class TicI2C(object):
def __init__(self, address):
self.address = address
# Sends the "Exit safe start" command.
def exit_safe_start(self):
command = [0x83]
i2c.writeto(self.address, bytes(command))
# Sets the target position.
# For more information about what this command does, see the
# "Set target position" command in the "Command reference" section of the
# Tic user's guide.
def set_target_position(self, target):
command = [0xE0,
target >> 0 & 0xFF,
target >> 8 & 0xFF,
target >> 16 & 0xFF,
target >> 24 & 0xFF]
# Gets one or more variables from the Tic.
i2c.writeto(self.address, bytes([0xA1, offset]))
return i2c.readfrom(self.address, length)
def get_current_position(self):
b = self.get_variables(0x22, 4)
position = b[0] + (b[1] << 8) + (b[2] << 16) + (b[3] << 24)
if position >= (1 << 31):
position -= (1 << 32)
return position
# Select the I2C address of the Tic (the device number).
address = 14
tic = TicI2C(address)
position = tic.get_current_position()
print("Current position is {}.".format(position))
new_target = -200 if position > 0 else 200
print("Setting target position to {}.".format(new_target));
tic.exit_safe_start()
tic.set_target_position(new_target)
