9. Reviving an unresponsive Zumo 32U4
9.1. Reviving using the Arduino IDE
9.2. Reviving using AVRDUDE
  • You accidentally loaded a malfunctioning program onto the device that is incapable of responding to the special USB command. For example, your program might be stuck in an infinite loop with interrupts disabled.
  • You loaded a program which uses a non-standard type of USB interface or no USB interface.
Zumo 32U4 OLED Main Board
Zumo 32U4 Main Board v1.1
Zumo 32U4 Front Sensor Array
Zumo 32U4 Main Board v1.0
