Support » Pololu RC Switch User’s Guide » 9. Configuring Your RC Switch »
9.2. Restoring the Default Settings
This section gives steps for restoring the switch to its default settings. This is a good thing to try if you have any trouble using the switch. The general configuration procedure is documented in Section 9.1, but the instructions here are easier to follow if you just want to restore the device to its default settings. To follow these instructions, you will need to know how to connect and disconnect the learning mode jumper, as described in Section 9.
- Get the device into learning mode. In order to do this, power off the device, connect the learning mode jumper, and then power it on. After it is powered on, you should disconnect the learning mode jumper. At this point, you will see the indicator LED fading in and out with a period of 1 second.
- Tap the learning mode jumper (connect it and then disconnect it). The indicator LED should be blinking a different pattern now.
- Power off the device to exit learning mode.
After following these instructions, the threshold should be 1696 μs and inversion should be disabled.
