5. Compiling AVRDUDE
Checking the currently installed version of AVRDUDE
Run the following command:
avrdude -v
You need at least version 5.6 for ATmega328P support.
Downloading the source code
Get the latest version from the AVRDUDE web site.
Unpacking the archive
tar xzf ~/Desktop/avrdude-5.6.tar.gz
cd avrdude-5.6
Compiling and installing AVRDUDE
Unlike the other packages, AVRDUDE does not need to be specifically told to compile for the AVR. So you should be able to compile it with no special options:
./configure
make
sudo make install
Optional: configuring earlier versions of AVRDUDE for the ATmega328P
The following configuration file will let versions of AVRDUDE before 5.6 work with the 328. Just copy these definitions to the end of avrdude.conf, which can be found in /etc, /usr/local/etc, or sometimes in the same directory as the avrdude executable.
# ATmega328P
part
    id              = "m328p";
    desc            = "ATMEGA328P";
     has_debugwire = yes;
     flash_instr   = 0xB6, 0x01, 0x11;
     eeprom_instr  = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
                     0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
                     0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode  = 0x86;
    # avr910_devcode = 0x;
    signature       = 0x1e 0x95 0x0F;
    pagel           = 0xd7;
    bs2             = 0xc2;
    chip_erase_delay = 9000;
    pgm_enable       = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
                       "x x x x x x x x x x x x x x x x";
    chip_erase       = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout         = 200;
    stabdelay       = 100;
    cmdexedelay     = 25;
    synchloops      = 32;
    bytedelay       = 0;
    pollindex       = 3;
    pollvalue       = 0x53;
    predelay        = 1;
    postdelay       = 1;
    pollmethod      = 1;
    pp_controlstack     =
        0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
        0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
        0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
        0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 5;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    resetdelay          = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
        paged           = no;
        page_size       = 4;
        size            = 1024;
        min_write_delay = 3600;
        max_write_delay = 3600;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read            = " 1 0 1 0 0 0 0 0",
                          " 0 0 0 x x x a9 a8",
                          " a7 a6 a5 a4 a3 a2 a1 a0",
                          " o o o o o o o o";
        write           = " 1 1 0 0 0 0 0 0",
                          " i i i i i i i i";
        loadpage_lo     = "  1   1   0   0      0   0   0   1",
                          "  0   0   0   0      0   0   0   0",
                          "  0   0   0   0      0   0  a1  a0",
                          "  i   i   i   i      i   i   i   i";
        writepage       = "  1   1   0   0      0   0   1   0",
                          "  0   0   x   x      x   x   a9  a8",
                          " a7  a6  a5  a4     a3  a2   0   0",
                          "  x   x   x   x      x   x   x   x";
        mode            = 0x41;
        delay           = 5;
        blocksize       = 4;
        readsize        = 256;
    memory "flash"
        paged           = yes;
        size            = 32768;
        page_size       = 128;
        num_pages       = 256;
        min_write_delay = 4500;
        max_write_delay = 4500;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read_lo         = " 0 0 1 0 0 0 0 0",
                          " 0 0 a13 a12 a11 a10 a9 a8",
                          " o o o o o o o o";
        read_hi          = " 0 0 1 0 1 0 0 0",
                           " o o o o o o o o";
        loadpage_lo     = " 0 1 0 0 0 0 0 0",
                          " 0 0 0 x x x x x",
                          " x x a5 a4 a3 a2 a1 a0",
                          " i i i i i i i i";
        loadpage_hi     = " 0 1 0 0 1 0 0 0",
                          " 0 0 0 x x x x x",
                          " i i i i i i i i";
        writepage       = " 0 1 0 0 1 1 0 0",
                          " a7 a6 x x x x x x",
                          " x x x x x x x x";
        mode        = 0x41;
        delay       = 6;
        blocksize   = 128;
        readsize    = 256;
    memory "lfuse"
        size            = 1;
        read            = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
                          "x x x x x x x x o o o o o o o o";
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
                          "x x x x x x x x i i i i i i i i";
    memory "hfuse"
        size            = 1;
        read            = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
        size            = 1;
        read            = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
                          "x x x x x x x x x x x x x o o o";
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
                          "x x x x x x x x x x x x x i i i";
    memory "lock"
        size            = 1;
        read            = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
                          "x x x x x x x x x x o o o o o o";
        write           = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
                          "x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
        size            = 1;
        read            = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
                          "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
        size            = 3;
        read            = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
                          "x x x x x x a1 a0 o o o o o o o o";
New Products
JST SH-Style Cable, 2-Pin, Female-Female, 10cm
5V, 500mA Step-Down Voltage Regulator D45V5F5
TB67S581FNG Stepper Motor Driver Carrier (Soldered Header Pins)
JST SH-Style Connector Board for Micro Metal Gearmotors, 2-Pin, Back-Entry (2-Pack)
JST SH-Style Cable, 2-Pin, Female-Female, 25cm
ACS37041KLHBLT-010B5 Current Sensor Micro Carrier -10A to +10A, 5V
ACS72981ELRATR-200B3 Current Sensor Compact Carrier -200A to +200A, 3.3V
CT433-HSWF20DR TMR Current Sensor Compact Carrier 0A to 20A, 3.3V
JST SH-Style Cable, 4-Pin, Single-Ended Female, 75cm
