4. Compiling avr-libc
Downloading the archive
Get the latest version from the avr-libc website. You should get version 1.6.6 or higher.
Configuring and compiling avr-libc
Run the following command:
tar xjf ~/Desktop/avr-libc-1.6.6.tar.bz2
cd avr-libc-1.6.6
Compiling avr-libc
Make sure that the latest avr-gcc is on your path as the default avr-gcc before you run these commands, or you will not get support for the mega328. When running configure, you should see a line of output that says (make sure “checking if avr-gcc has support for atmega328p… yes”. If you don’t see this, double-check your avr-gcc installation.
./configure --host=avr --prefix=/usr/local
make
sudo make install
Next steps
You should now have an avr-libc installed that includes support for the mega328, so you will be able to compile programs for this microcontroller. To program a chip, you will probably want AVRDUDE. Section 5 contains instructions for compiling installing and installing the latest version.
New Products
APM81815 Step-Down Voltage Regulator Carrier, 5V Out
ACS37030LMYATR-040B3 Current Sensor Compact Carrier -40A to +40A, 3.3V
ACS37200LLXTR-100B3 Current Sensor Compact Carrier -100A to +100A, 3.3V
ACS37100LMATR-050B3 TMR Current Sensor Large Carrier -50A to +50A, 3.3V
ACS37100LMATR-025B3 TMR Current Sensor Compact Carrier -25A to +25A, 3.3V
Glideforce GF01-120505-2-66 Micro Linear Actuator with Feedback Potentiometer: 12V, 2.2kgf, 28mm/s, 50mm Stroke
ACS37200LLXTR-200B3 Current Sensor Large Carrier -200A to +200A, 3.3V
ACS37030LMYATR-065B3 Current Sensor Large Carrier -65A to +65A, 3.3V
