7. AVR Pin Assignment Table Sorted by Pin
 Port  Pin  Orangutan Function   Notes/Alternate Functions
B
PB0 LCD control line R/W Timer1 input capture (ICP1)
divided system clock output (CLK0)
PB1 LCD data line DB4 user pushbutton (pressing pulls pin low)
Timer1 PWM output A (OC1A)
PB2 buzzer Timer1 PWM output B (OC1B)
PB3 M2 control line Timer2 PWM output A (OC2A)
ISP programming line
PB4 LCD data line DB5 user pushbutton (pressing pulls pin low)
Caution: also an ISP programming line
PB5 LCD data line DB6 user pushbutton (pressing pulls pin low)
PB6 20 MHz resonator input not accessable to the user
PB7 20 MHz resonator input not accessable to the user
C
PC0 analog input and digital I/O ADC input channel 0 (ADC0)
PC1 analog input and digital I/O ADC input channel 1 (ADC1)
PC2 analog input and digital I/O ADC input channel 2 (ADC2)
PC3 analog input and digital I/O ADC input channel 3 (ADC3)
PC4 analog input and digital I/O ADC input channel 4 (ADC4)
I2C/TWI input/output data line (SDA)
PC5 analog input and digital I/O ADC input channel 5 (ADC5)
I2C/TWI clock line (SCL)
PC6 RESET pin reset button (pressing resets MCU)
digital I/O disabled by default
D
PD0 digital I/O USART input pin (RXD)
PD1 digital I/O connected to red user LED (high turns LED on)
USART output pin (TXD)
PD2 LCD control line RS external interrupt 0 (INT0)
PD3 M2 control line Timer2 PWM output B (OC2B)
PD4 LCD control line E USART external clock input/output (XCK)
Timer0 external counter (T0)
PD5 M1 control line Timer0 PWM output B (OC0B)
PD6 M1 control line Timer0 PWM output A (OC0A)
PD7 LCD data line DB7 connected to green user LED (high turns LED on)
ADC6
dedicated analog input SMT-jumpered to temperature sensor (LV-168 only)
SMT-jumpered to battery voltage monitor (SV-xx8 only)
ADC input channel 6 (ADC6)
ADC7
dedicated analog input connected to user trimmer potentiometer
ADC input channel 7
