Support »
Comparison of Solarbotics Gearmotors (GM Series)
Solarbotics provides a variety of gearmotors that are great for building small robots. The following table compares major features of the Solarbotics GM gearmotors we carry.
gear motor | size | weight | gear ratio | free-run RPM |
free-run current |
stall current | stall torque | clutch | output shaft | wheels | |
55 × 48 × 23 mm 2.17 × 1.89 × 0.906 in |
37 g 1.31 oz |
224:1 | 38 rpm @ 5 V |
52 mA @ 5 V |
600 mA @ 5 V |
50 oz * in @ 5 V |
engages at ~60 oz * in | 7 mm diameter two sides flattened |
GMPW wheels | |
70 × 22.5 × 37 mm 2.76 × 0.886 × 1.46 in |
37 g 1.31 oz |
52 mA @ 5 V |
600 mA @ 5 V |
50 oz * in @ 5 V |
GMPW wheels | |
32 g 1.13 oz |
143:1 | 70 rpm @ 5 V |
57.6 mA @ 5 V |
670 mA @ 5 V |
43 oz * in @ 5 V |
clutch included | 7 mm diameter two sides flattened slightly shorter than GM2/GM3 |
GMPW wheels | |
70.5 × 27 × 23 mm 2.78 × 1.06 × 0.906 in |
32 g 1.13 oz |
143:1 | 66 rpm @ 5 V |
73.2 mA @ 5 V |
670 mA @ 5 V |
43 oz * in @ 5 V |
GMPW wheels | |
37 × 21 × 27 mm 1.45 × 0.83 × 1.06 in |
20 g 0.7 oz |
120:1 | 145 rpm @ 5 V 7 rpm @ 0.58 V |
88 mA @ 5 V 46.5 mA @ 0.58 V |
610 mA @ 5 V |
20 oz * in @ 5 V |
engages at ~25 oz * in produced @ 6.5 V drawing 650 mA |
2 mm-crest diameter splined |
GM6/GM7 laser-cut wheels | |
53 × 13 × 19 mm 2.09 × 0.51 × 0.75 in |
20 g 0.7 oz |
7 rpm @ 0.58 V |
88 mA @ 5 V
46.5 mA @ 0.58 V |
610 mA @ 5 V |
20 oz * in @ 5 V |
1 × 0.56 × 1.14 in | 5 g | 81:1 | 370 rpm @ 5 V | 24.6 mA @ 5 V | 184 mA @ 5 V |
3.6 oz * in @ 5 V |
none | 0.14-inch square | GM10 wheels | |
29 × 10 × 12 mm 1.14 × 0.39 × 0.47 in |
8.2 g 0.29 oz |
30:1 | 566 rpm @ 6 V | 48 mA @ 6 V | 500 mA @ 6 V |
7.29 oz * in @ 6 V |
none | 3 mm diameter | RW2 wheels | |
8.2 g 0.29 oz |
100:1 | 170 rpm @ 6 V | 48 mA @ 6 V | 390 mA @ 6 V |
10.7 oz * in @ 6 V |
8.2 g 0.29 oz |
150:1 | 113 rpm @ 6 V | 40 mA @ 6 V | 370 mA @ 6 V |
14.97 oz * in @ 6 V |
8.2 g 0.29 oz |
298:1 | 71 rpm @ 6 V | 50 mA @ 6 V | 533 mA @ 6 V |
30.7 oz * in @ 6 V |
free-run current |
