Support » Pololu 3pi+ 2040 User’s Guide » 1. Overview »
The 3pi+ 2040 robot is available as a kit or fully assembled with three different motor options:
3pi+ 2040 Version | Products | Micro Metal Gearmotor | Top Speed | Comments |
Standard Edition | assembled or kit | 30:1 MP 6V | 1.5 m/s | good combination of speed and controllability |
Turtle Edition | assembled or kit | 75:1 LP 6V | 0.4 m/s | longest battery life, easiest to control, good for swarm robots or introductory robotics courses |
Hyper Edition | assembled or kit | 15:1 HPCB 6V | ~4 m/s | very fast and difficult to control, easy to damage; only recommended for advanced users |
In addition, the 3pi+ chassis and 3pi+ 2040 control board are available separately and can be combined with the motors of your choice to make a custom kit.
A version of the 3pi+ robot based on the Arduino-compatible ATmega32U4 MCU is also available. See the 3pi+ 32U4 OLED Robot for more information.
3pi+ 2040 robot kit contents
The kit versions of the 3pi+ 2040 robot include the following items:
- 3pi+ Chassis Kit, which includes:
- 3pi+ chassis, with integrated 4×AAA battery holder and ball caster
- 3pi+ bumper skirt
- two 3pi+ motor clips
- two 32×7 mm Pololu wheel hubs and silicone tires
- four single AAA battery contacts
- two double AAA battery contacts
- 1/2″-diameter plastic ball
- 3pi+ 2040 Control Board, which includes:
- control board
- buzzer
- jumper wires (for soldering motors to the main board)
- 1×7 low-profile male header for OLED display
- two magnetic encoder discs (12 CPR)
- four 3/16″ #2-56 screws and nuts
- two 1/4″ #2-56 standoffs
- two Micro Metal Gearmotors (the table above lists the specific motors included with each edition)
- graphical OLED display with black PCB
- spare 15:1 gearbox (Hyper Edition only)
The robot and chassis kit might include extra parts like jumper wires, screws, and nuts, so do not be concerned if you have some leftover hardware after assembling your 3pi+.
Assembled 3pi+ 2040 robot
The assembled versions of the 3pi+ 2040 robot are complete, ready-to-program robot platforms built from the same components found in the 3pi+ 2040 robot kits; no soldering or assembly is required.
