Support » Pololu Simple Motor Controller G2 User’s Guide » 1. Overview »
1.1. 18v15 and 24v12 included hardware
High-Power Simple Motor Controller G2 18v15 or 24v12, bottom view with dimensions. |
Pinout diagram of the High-Power Simple Motor Controller G2 18v15 or 24v12. |
The 18v15 and 24v12 versions are available with connectors included but not soldered in or with the connectors pre-installed.
The terminal blocks are only rated for 16 A, so for higher-power applications, we recommend soldering thick wires directly to the board.
These files provide further documentation of the hardware design of the Simple Motor Controller G2 18v15 and 24v12:
- Dimension diagram (424k pdf)
- 3D model (12MB step)
- Drill guide (100k dxf)
