3.13. Schematics and dimensions
Schematics
The schematic diagram for the Zumo 32U4 robot is available as a PDF:
- Zumo 32U4 OLED schematic diagram (408k pdf)
- Zumo 32U4 schematic diagram (419k pdf) (original LCD version)
Dimensions
A basic dimension diagram for the Zumo 32U4 Main Board is available as a PDF:
- Zumo 32U4 OLED Main Board dimension diagram (572k pdf)
- Zumo 32U4 Main Board dimension diagram (1MB pdf) (original LCD version)
Dimensions that are not included in the above diagram can be measured from the following DXF drawings:
- Zumo 32U4 OLED Main Board drill guide (200k dxf)
- Zumo 32U4 Main Board drill guide (239k dxf) (original LCD version)
3D models of the Zumo 32U4 Main Board and robot are also available in STEP format:
- Zumo 32U4 OLED Main Board 3D model (24MB step)
- Zumo 32U4 OLED robot 3D model (44MB step)
- Note: This model uses simplified models of the control electronics to reduce the file size.
- Zumo 32U4 Main Board v1.1 3D model (25MB step) (original LCD version)
- Zumo 32U4 robot 3D model (43MB step) (original LCD version)
The following pictures show the approximate dimensions of the Zumo chassis used by the Zumo 32U4 robot:
