3.10. Pin assignments
The table below lists the most important pin assignments for the ATmega32U4 on the Zumo 32U4. This table is helpful if you want to add your own electronics to the Zumo 32U4, write your own low-level code for interfacing with the hardware, or just want to understand better how the Zumo 32U4 works. Each row represents a physical pin on the ATmega32U4.
The “Arduino pin names” column lists the names provided by the Arduino environment for the pin.  These names can generally be used as arguments to any function that takes a pin number.  However, there are some exceptions.  For example, passing the number 4 to analogRead actually reads pin A4, not pin 4.  Also, due to hardware limitations, some functions only work on a limited set of pins.
The “Zumo 32U4 functions” column documents what the pin is used for on the Zumo 32U4. Many pins can serve multiple purposes concurrently by switching modes. For example, PB0 can read the state of button C when it is an input, and it can control the red LED and serve as a display data line when it is an output.
| ATmega32U4 pin name  | Arduino pin names  | Zumo 32U4 functions | Notes/alternate functions |
| PB7 | 11 | Line sensor IR LED control |
Timer0 PWM output A (OC0A) Timer1 PWM output C (OC1C) UART flow control (RTS) Pin-change interrupt (PCINT7)  |
| PF7 | A0, 18 | Line sensor 1 (leftmost) | Analog input (ADC7) JTAG test data in (TDI)  |
| PF5 | A2, 20 | Line sensor 2 Left proximity sensor (function selected by jumper)  |
Analog input (ADC5) JTAG test mode select (TMS)  |
| PF4 | A3, 21 | Line sensor 3 (center) | Analog input (ADC4) JTAG test clock (TCK)  |
| PD4 | 4, A6, 24 | Line sensor 4 Right proximity sensor output (function selected by jumper)  |
Analog input (ADC8) Timer1 input capture pin (ICP1)  |
| PD6 | 12, A11, 29 | Line sensor 5 (rightmost) | Analog input (ADC9) Timer4 PWM output D (OC4D) Timer1 counter source (T1)  |
| PF1 | A4, 22 | Front proximity sensor | Analog input (ADC1) |
| PC6 | 5 | Proximity LED PWM | Timer3 PWM output A (OC3A) Timer4 PWM output A (OC4A)  |
| PF6 | A1, 19 | Proximity LED selection Battery level input (VBAT/2)  | Analog input (ADC6) JTAG test data out (TDO)  |
| PD2 | 0 | OLED version: Display reset (RESET) LCD version: LCD control line (RS)  | UART receive pin (RXD1) External interrupt source (INT2)  |
| PD3 | 1 | OLED version: Display SPI clock (SCK) LCD version: LCD control line (E)  | UART transmit pin (TXD1) External interrupt source (INT3)  |
| PB3 | 14, MISO | User pushbutton A LCD version: LCD data line DB4  | SPI Master Input/Slave Output (MISO) Pin-change interrupt (PCINT3)  |
| PB0 | 17, SS | Red LED (RX) User pushbutton C OLED version: Display data/command select (D/C) LCD version: LCD data line DB5  | SPI slave select (SS) Pin-change interrupt (PCINT0)  |
| PC7 | 13 | Yellow LED LCD version: LCD data line DB6  | Timer4 PWM output A (OC4A) Timer3 input capture pin (ICP3) Divided system clock output (CLKO)  |
| PD5 | - | Green LED (TX) User pushbutton B OLED version: Display data (MOSI) LCD version: LCD data line DB7  | UART external clock (XCK1) UART flow control (CTS)  |
| PD7 | 6, A7, 25 | Buzzer PWM | Analog input (ADC10) Timer4 PWM output D (OC4D) Timer0 counter source (T0)  |
| PB6 | 10, A10, 28 | Left motor PWM | Analog input (ADC13) Timer1 PWM output B (OC1B) Timer4 PWM output B (OC4B) Pin-change interrupt (PCINT6)  |
| PB2 | 16, MOSI | Left motor direction | SPI Master Output/Slave Input (MOSI) Pin-change interrupt (PCINT2)  |
| PB5 | 9, A9, 27 | Right motor PWM | Analog input (ADC12) Timer1 PWM output A (OC1A) Timer4 PWM output B (OC4B) Pin-change interrupt (PCINT5)  |
| PB1 | 15, SCK | Right motor direction | SPI Clock (SCK) Pin-change interrupt (PCINT1)  |
| PB4 | 8, A8, 26 | Left encoder XORed input | Analog input (ADC11) Pin-change interrupt (PCINT4)  |
| PE2 | - | Left encoder input | Hardware bootloader select (HWB) |
| PE6 | 7 | Right encoder XORed input | Analog comparator negative input (AIN0) External interrupt source (INT6)  |
| PF0 | A5, 23 | Right encoder input | Analog input (ADC0) |
| PD0 | 3, SCL | I²C clock for inertial sensors | Timer0 PWM output B (OC0B) External interrupt source (INT0)  |
| PD1 | 2, SDA | I²C data for inertial sensors | External interrupt source (INT1) |
| RESET | - | Reset pushbutton | internally pulled high, active low |
| AREF | - | - | Analog reference |
