6. Compiling and running the program
Instructions for compilation are defined in the Makefile. Type make and all of the C files will be combined into a shared object (or DLL) called ssctester.so. Since there is no main function, this is not a program you can run by yourself, just a library of functions that will be used by ssc-tester.tcl. That file is a script, which means that it is interpreted on the fly and does not need to be compiled. To run it, type
wish ssc-tester.tcl
and a window with 16 sliders should appear. Connect the servo controller and a servo, then try moving the sliders to see if it works!
New Products
Pololu G2 High-Power Motor Driver 24v30 CS
TB67S579FTG Stepper Motor Driver Compact Carrier
20.4:1 Metal Gearmotor 25Dx65L mm HP 24V with 48 CPR Encoder
MP6602 Stepper Motor Driver Carrier
Pololu Isolated Solid State Relay/Switch, SPST, 100V, 4.5A
ACS37200LLXTR-100B5 Current Sensor Large Carrier -100A to +100A, 5V
Pololu Reverse Voltage Protector, 4-75V, 17A
TPS2116 Power Multiplexer Carrier with USB Type-C Connector (non-USB priority)
ACS37200LLXTR-150B5 Current Sensor Compact Carrier -150A to +150A, 5V
