8. The 3pi+ 32U4 USB interface
Windows 10 Device Manager showing the A-Star’s virtual COM port.
The Windows 10 Device Manager in “Devices by connection” mode, showing that the A-Star is a composite device.
On a Linux computer, you can see details about the USB interface by running lsusb -v -d 1ffb: in a Terminal. The virtual serial port can be found by running ls /dev/ttyACM* in a Terminal.
On a Mac OS X computer, the virtual serial port can be found by running ls /dev/tty.usbmodem* in a Terminal.
3pi+ 32U4 Control Board
3pi+ 32U4 OLED Control Board
