Support »
Pololu Romi 32U4 Control Board User’s Guide
- 1. Overview
- 2. Contacting Pololu
- 3. Romi 32U4 Control Board
- 4. Assembling the Romi 32U4 Control Board
- 5. Programming the Romi 32U4 Control Board
- 6. Romi 32U4 Arduino library
- 7. The Romi 32U4 USB interface
- 8. The A-Star 32U4 Bootloader
- 9. Reviving an unresponsive Romi 32U4
- 10. Related resources
The Romi 32U4 Control Board is designed to be assembled with a Romi chassis to create a capable integrated robot platform that can easily be programmed and customized.
Like our A-Star 32U4 programmable controllers, the Romi 32U4 Control Board is built around a USB-enabled Atmel ATmega32U4 AVR microcontroller, and it ships preloaded with an Arduino-compatible bootloader. The control board features two H-bridge motor drivers and is designed to connect to a Romi Encoder Pair Kit (available separately) to allow closed-loop motor control. It also includes a powerful 5 V switching step-down regulator that can supply up to 2 A continuously, along with a versatile power switching and distribution circuit. A 3-axis accelerometer and gyro enable a Romi 32U4 robot to make inertial measurements, estimate its orientation, and detect external forces. Three on-board pushbuttons offer a convenient interface for user input, while indicator LEDs, a buzzer, and a connector for an optional LCD allow the robot to provide feedback.
The Romi 32U4 Control Board can be used either as a standalone control solution or as a base for a more powerful Raspberry Pi controller. Its on-board connector and mounting holes allow a compatible Raspberry Pi (Model B+ or newer, including Pi 3 Model B and Model A+) to plug directly into the control board. Integrated level shifters make it easy to set up I²C communication and interface other signals between the two controllers, and the control board automatically supplies 5 V power to an attached Raspberry Pi. In this setup, the Raspberry Pi can handle the high-level robot control while relying on the Romi 32U4 Control Board for low-level tasks, like running motors, reading encoders, and interfacing with other analog or timing-sensitive devices.
The I/O lines of both the ATmega32U4 and the Raspberry Pi are broken out to 0.1″-spaced through-holes along the front and rear of the control board, and the board’s power rails are similarly accessible, enabling sensors and other peripherals to easily be connected.
A software add-on is available that makes it easy to program a Romi 32U4 robot from the Arduino environment, and we have Arduino libraries and example sketches to help get you started. A USB A to Micro-B cable (not included) is required for programming.
1.1. Included components
The following components are included with the Romi 32U4 Control Board:
- two low profile female headers for motors and encoders
- buzzer
- 2×7 female header and male header for LCD
- battery terminals
- four 3/16″ #2-56 screws and nuts
- four M2.5 standoffs (11 mm length), screws, and nuts for mounting Raspberry Pi
An LCD and Raspberry Pi are not included with the Romi 32U4 Control Board.
1.2. What you will need
These additional items are also needed for using and assembling the Romi 32U4 Control Board:
Required accessories
- a Romi Chassis Kit (this includes motors, wheels, one ball caster, and battery contacts)
- a Romi Encoder Pair Kit
- six AA batteries. The Romi chassis and control board work with both alkaline and NiMH batteries, though we recommend rechargeable NiMH cells.
Assembly tools
- soldering iron and solder (we recommend one with adjustable temperature control like the Hakko FX-888D Digital Soldering Station)
- small Phillips screwdriver
- USB A to Micro-B cable to connect the board to your computer for programming and debugging
Optional tools
- small 2 mm slotted screwdriver for adjusting the LCD contrast
- small pair of pliers
- wire cutter and stripper, for adding wires for peripherals
- tape or small clamps (for holding parts together when soldering)
Optional accessories
You might also consider getting these for your Romi 32U4 Robot:
- an 8×2 character LCD
- a compatible Raspberry Pi (Model B+ or newer, including Pi 3 Model B and Model A+)
- sensors, such as optical or sonar range finders
- connectors and jumper wires, for connecting additional sensors and components
- battery charger, if you are using rechargeable batteries; since the Romi just uses ordinary AA batteries, we recommend basic AA chargers (into which you stick the individual cells) available at most general electronics stores, though we carry a much fancier iMAX-B6AC V2 balance charger/discharger that can be also used for this
The Romi 32U4 Control Board can be programmed using Microsoft Windows 11, 10, 8.1, 8, 7, Vista, XP (with Service Pack 3), Linux, and macOS 10.11 or later.
We would be delighted to hear from you about any of your projects and about your experience with the Romi 32U4 Control Board. You can contact us directly or post on our forum. Tell us what we did well, what we could improve, what you would like to see in the future, or anything else you would like to say!
3.1. Microcontroller
Like our A-Star 32U4 programmable controllers, the Romi 32U4 Control Board features an integrated, USB-enabled ATmega32U4 AVR microcontroller from Atmel, clocked by a precision 16 MHz crystal oscillator. This is the same microcontroller and clock frequency used in the Arduino Leonardo and Arduino Micro.
The control board includes a USB Micro-B connector that can be used to connect to a computer’s USB port via a USB A to Micro-B cable (not included). The USB connection can be used to transmit and receive data from the computer and program the board over USB. The USB connection can also provide power for the microcontroller and most of the other hardware on the board (but not motor power); see Section 3.5 for more details.
The control board’s ATmega32U4 comes preloaded with the Arduino-compatible A-Star 32U4 USB bootloader, which allows it to be easily programmed using the Arduino IDE. For more information about programming the Romi 32U4 Control Board, see Section 5.
The board also has a 6-pin ISP header that allows it to be programmed with an external programmer, such as our USB AVR programmer. Pin 1 of the header is indicated with a small white dot and has an octagonal shape.
3.2. User interface
LEDs
The Romi 32U4 Control Board has five indicator LEDs.
- A yellow user LED is connected to Arduino digital pin 13, or PC7. You can drive this pin high in a user program to turn this LED on. The A-Star 32U4 Bootloader fades this LED on and off while it is waiting for a sketch to be loaded.
- A green user LED is connected to Arduino pin 30, or PD5, and lights when the pin is driven low. While the board is running the A-Star 32U4 Bootloader or a program compiled in the Arduino environment, it will flash this LED when it is transmitting data via the USB connection.
The Romi32U4 library contains functions that make it easier to control the three user LEDs (see Section 6). All three user LED control lines are also LCD data lines, so you will see them flicker when you update the LCD. The green and red user LEDs also share I/O lines with pushbuttons (see below).
- A blue power LED next to the power switch indicates when the controller is receiving power from the Romi’s batteries (the power switching circuit must be turned on).
- A green power LED on the bottom edge of the board near the USB connector indicates when the USB bus voltage (VBUS) is present.
Pushbuttons
The Romi 32U4 Control Board has five pushbuttons: a power button in the rear left corner, a reset button on the front right edge and three user pushbuttons located along the rear edge. The user pushbuttons, labeled A, B, and C, are on Arduino pin 14 (PB3), pin 30 (PD5), and pin 17 (PB0), respectively. Pressing one of these buttons pulls the associated I/O pin to ground through a resistor.
The three buttons’ I/O lines are also used for other purposes: pin 14 is MISO on the SPI interface, pin 30 and pin 17 control the green and red user LEDs, and all three pins are LCD data lines. Although these uses require the pins to be driven by the AVR (or SPI slave devices in the case of MISO), resistors in the button circuits ensure that the Romi 32U4 Control Board will not be damaged even if the corresponding buttons are pressed at the same time, nor will SPI or LCD communications be disrupted. The functions in the Romi32U4 library take care of configuring the pins, reading and debouncing the buttons, and restoring the pins to their original states.
LCD
The Romi 32U4 Control Board has a set of through-holes in the center where a 2×7 header can be soldered to connect an 8×2 character LCD (or any other LCD with the common HD44780 parallel interface (109k pdf)). You can adjust the LCD contrast with the potentiometer on the top right of the LCD connector. We recommend using a 2 mm slotted screwdriver to adjust the contrast.
The Romi32U4 library provides functions to display data on a connected LCD. It is designed to gracefully handle alternate use of the LCD data lines by only changing pin states when needed for an LCD command, after which it will restore them to their previous states. This allows the LCD data lines to be used for other functions (such as pushbutton inputs and LED drivers).
Note that the control board is not designed to allow both an LCD and a Raspberry Pi to plug into it at the same time. However, having an LCD header soldered to the board should not interfere with mounting a Raspberry Pi.
Buzzer
The buzzer included with the Romi 32U4 Control Board can be soldered into the designated through-holes and used to generate simple sounds and music. By default, it is connected to digital pin 6 (which also serves as OC4D, a hardware PWM output from the AVR’s 10-bit Timer4). If you alternate between driving the buzzer pin high and low at a given frequency, the buzzer will produce sound at that frequency. You can play notes and music with the buzzer using functions in the Romi32U4 library. If you want to use pin 6 for an alternate purpose, you can disconnect the buzzer circuit by cutting the surface-mount jumper next to the buzzer.
3.3. Motor drivers and encoders
Motor drivers
The Romi 32U4 Control Board has two Texas Instruments DRV8838 motor drivers that are used to power the Romi chassis’s two mini plastic gearmotors. Four Arduino pins are used to control the drivers:
- Digital pin 15, or PB1, controls the right motor direction (LOW drives the motor forward, HIGH drives it in reverse).
- Digital pin 16, or PB2, controls the left motor direction.
- Digital pin 9, or PB5, controls the right motor speed with PWM (pulse width modulation) generated by the ATmega32U4’s Timer1.
- Digital pin 10, or PB6, controls the left motor speed with PWM.
For more information about the drivers, see the DRV8838 datasheet (1k redirect). We also sell a carrier board for this driver.
The Romi32U4 library provides functions that allow you to easily control the motors (see Section 6).
The motor driver connections are brought out to two pairs of headers that are intended to interface with the Romi Encoder Pair Kit. A pair of low-profile female headers is included with the Romi 32U4 Control Board and can be soldered into either the outer or inner row of through-holes on each side. (Note that these headers must be soldered into the positions that match the male header installed on the encoder board.)
As your batteries run out, the voltage supplied to the motor drivers (VSW) will decrease, which will make the motors slower. It is possible to account for this in your code by monitoring the battery voltage (see Section 3.5) or using the encoders and other sensors to monitor the movement of the robot.
Quadrature encoders
The Romi 32U4 Control Board is configured to connect the quadrature encoder outputs from the Romi Encoder Pair Kit to the ATmega32U4 microcontroller. The encoders can be used to track the rotational speed and direction of the robot’s drive wheels. They provide a resolution of 12 counts per revolution of the motor shaft when counting both edges of both channels, which corresponds to approximately 1440 counts per revolution of the Romi’s wheels. For more information about the specifications of the Romi encoders, please see the Romi Encoder Pair Kit product page.
Quadrature encoder transitions are often detected by monitoring both encoder channels directly. However, since transitions on the Romi’s encoders can occur at high frequencies (several thousand per second) when its motors are running, it is necessary to use the AVR’s pin change interrupts or external interrupts to read the encoders. To reduce the required number of interrupt pins, the Romi 32U4 Control Board XORs together both channels of each encoder and connects the resulting signal to an interrupt pin, while channel B of each encoder is connected to a non-interrupt pin:
- Digital pin 7, or PE6, reads the right encoder XORed signal using external interrupt INT6.
- Digital pin 8, or PB4, reads the left encoder XORed signal using pin change interrupt PCINT4.
- Digital pin 23 (analog pin 5), or PF0, reads the right encoder channel B.
- Pin PE2 reads the left encoder channel B.
The XORed signal and the channel B signal can be used to reconstruct the channel A signal by simply XORing them again: (A XOR B) XOR B = A. For both encoders, channel B leads channel A when the motor is rotating in the forward direction; that is, B rises before A rises and B falls before A falls. (The waveforms in the diagram above would be produced by forward rotation.) Note that this description designates the A and B signals as labeled on the control board itself, which puts A in front on both sides.
The Romi32U4 library provides appropriate interrupt service routines and functions for reading the encoders and keeping track of their counts (see Section 6).
3.4. Inertial sensors
The Romi 32U4 Control Board includes on-board inertial sensors connected to the ATmega32U4’s I²C interface that can be used in advanced applications, such as helping detect collisions and determining the robot’s orientation. These sensors are part of the ST LSM6DS33, which combines a 3-axis accelerometer and 3-axis gyro into a single package.
The inertial sensors are connected to the board’s I²C bus by default, but they can be disconnected by cutting the surface-mount jumpers labeled “IMU SDA Jmp” and “IMU SCL Jmp”. Level shifters built into the control board allow the ATmega32U4, operating at 5 V, to communicate with the 3.3 V sensors. If a Raspberry Pi is plugged into the control board, its I²C pins are connected to the 3.3 V side of the bus as well. (See Section 3.7 for more information about the Raspberry Pi interface.)
We recommend carefully reading the LSM6DS33 datasheet (1MB pdf) to understand how these sensors work and how to use them.
Using the sensors
The Romi32U4 library (see Section 6) includes example programs that demonstrate how to use the sensors.
3.5. Power
The Romi 32U4 Control Board includes battery terminal connections that provide access to power from the Romi chassis’s six-AA battery compartment. We recommend using rechargeable AA NiMH cells, which results in a nominal voltage of 7.2 V (1.2 V per cell). You can also use alkaline cells, which would nominally give you 9 V.
The negative battery voltage is connected to GND. The positive battery voltage is designated VBAT. VBAT feeds into a reverse protection circuit and then a power switching circuit controlled by the on-board pushbutton or slide switch. The output of the power switching circuit is designated VSW.
VSW provides power to the motors through the on-board DRV8838 motor drivers, so the motors can only operate if the batteries are installed and the power switch circuit is on.
The reverse protected and switched battery voltage on VSW can be monitored through a voltage divider that is connected to analog pin 1 (PF6) by default. The divider outputs a voltage that is equal to one third of the battery voltage, which will be safely below the ATmega32U4’s maximum analog input voltage of 5 V as long as the battery voltage is less than 15 V (though the maximum voltage for the board is still limited to 10.8 V by the DRV8838 motor driver). The readBatteryMillivolts()
function in the Romi32U4 library can be used to determine the battery voltage from this reading.
The surface-mount jumper labeled “A1 = BATLEV” can be cut to disconnect the voltage divider and free the pin for other uses.
Power switch circuit
The Romi 32U4 Control Board uses the patented latching circuit from the Pololu pushbutton power switch, which provides a solid-state power switch for your robot controlled with the on-board pushbutton. By default, this pushbutton can be used to toggle power: one push turns on power and another turns it off. Alternatively, a separate pushbutton can be connected to the PWRA and PWRB pins and used instead. Multiple pushbuttons can be wired in parallel for multiple control points, and each of the parallel pushbuttons, including the one on the board itself, will be able to turn the switch on or off. The latching circuit performs some button debouncing, but pushbuttons with excessive bouncing (several ms) might not function well with it.
For proper pushbutton operation, the board’s slide switch should be left in its Off position. (Sliding the switch to the On position will cause the board power to latch on, and the switch must be returned to the Off position before the board can be turned off with the pushbutton.)
Alternatively, to disable the pushbutton, you can cut the button jumper labeled Btn Jmp; this transfers control of the board’s power to the on-board slide switch instead. A separate slide or toggle switch can be connected to the GATE pin and used instead.
PIN | Description |
PWRA | Connect through momentary switch to pin “PWRB” for standard push-on/push-off operation. Connect through momentary switch to ground for on-only operation. |
PWRB | Connect through momentary switch to pin “PWRA” for standard push-on/push-off operation. |
ON | A high pulse (> 1 V) on this pin turns on the switch circuit. This pin only functions when pushbutton operation is enabled (i.e. the button jumper has not been cut). |
OFF | A high pulse (> 1 V) on this pin turns off the switch circuit (e.g. allowing a powered device to shut off its own power). This pin only functions when pushbutton operation is enabled. |
CTRL | With pushbutton operation enabled, this pin directly determines the state of the switch circuit. A high pulse (> 1 V) on this pin turns on the switch; a low pulse (e.g. driving the pin low with a microcontroller output line or pushing a button connected from this pin to ground) turns the switch off. Leave this pin disconnected or floating when not trying to set the switch state. Note that this pin should not be driven high at the same time the “OFF” pin is driven high. |
GATE | With pushbutton operation disabled (button jumper cut), this pin controls the state of the switch circuit: driving it low turns the switch on, while letting it float turns the switch off. Connect through slide or toggle switch to ground for on/off operation. Leave this pin disconnected or floating for proper pushbutton operation. We recommend only ever driving this pin low or leaving it floating; this pin should never be driven high while the slide switch is in the “On” position. |
5 V and 3.3 V regulators
VSW supplies power to a 5 V regulator, whose output is designated VREG. The battery voltage is regulated to 5 V by an MP4423H switching buck converter; although the regulator itself works with input voltages up to 36 V, the motor drivers limit the control board’s maximum input voltage to 10.8 V. When available, VREG is generally used to supply logic power for the ATmega32U4, motor drivers, and encoders. The rest of the regulator’s achievable output current, which depends on input voltage and ambient conditions, can be used to power other devices; this can include an attached Raspberry Pi (which typically draws a few hundred milliamps). Under typical conditions, up to 2 A of current is available from the VREG output. (We also make a standalone regulator based on this integrated circuit.)
The MP4423H regulator features an open-drain power good output, PG, which requires an external pull-up. PG drives low when the 5 V regulator’s output voltage falls below around 85% of the nominal voltage and becomes high-impedance when the output voltage rises above around 90%. The regulator circuit on the Romi 32U4 Control Board can be disabled by driving the regulator shutdown pin, REGSHDN, high; this will cause 5 V logic power for the control board to be sourced from USB instead if it is available.
The Romi 32U4 Control Board also contains a 3.3 V LDO that draws its power from the output of the logic power selection circuit described below. The output of the 3.3 V regulator is designated 3V3 and is used to supply the on-board inertial sensors and level shifters.
Logic power selection
The Romi 32U4 Control Board’s power selection circuit uses the TPS2113A power multiplexer from Texas Instruments to choose whether its 5 V supply (designated 5V) is sourced from USB or the batteries via the 5 V regulator, enabling the control board to safely and seamlessly transition between them. The TPS2113A is configured to select regulated battery power (VREG) unless the regulator output falls below about 4.5 V. If this happens, it will select the higher of the two sources, which will typically be the USB 5 V bus voltage if the control board is connected to USB.
Consequently, when the Romi 32U4 Control Board is connected to a computer via USB, it will receive 5 V logic power even when the power switch is off. This can be useful if you want to upload or test a program without drawing power from the batteries and without operating the motors. It is safe to have USB connected and battery power switched on at the same time.
The currently selected source is indicated by the STAT pin; this pin is an open-drain output that is low if the external power source is selected and high-impedance if the USB supply is selected. The current limit of the TPS2113A is set to about 1.9 A nominally. For more information about the power multiplexer, see the TPS2113A datasheet (1k redirect).
The 5 V output of the selection circuit is used to supply the control board’s ATmega32U4 microcontroller, logic power for the DRV8838 motor drivers, and the encoders; it also optionally powers an attached Raspberry Pi.
Raspberry Pi power
By default, the control board will provide power from its 5V line to an attached Raspberry Pi. In this situation, we recommend switching on the power circuit so that the Raspberry Pi receives power from the batteries through the control board’s on-board switching regulator. Alternatively, you can use a USB wall power adapter to supply power through the control board’s USB connector, although we have sometimes observed AVR brown-out resets occurring when a board powers the Raspberry Pi this way. A typical computer USB port might not be able to supply enough current to properly power the Romi 23U4 Control Board and an attached Raspberry Pi.
Power provided to the Raspberry Pi can be switched off by driving the Raspberry Pi shutdown pin, RPISHDN, to 5 V.
An ideal diode circuit on the control board prevents reverse current from flowing into the Romi 32U4 Control Board’s 5 V supply if the Raspberry Pi is separately powered (for example, through its USB power receptacle). However, starting with the Raspberry Pi 3 Model B+, there is no corresponding ideal diode circuit on the Raspberry Pi’s USB power input, so it is possible for the control board to backfeed a USB power adapter through the Raspberry Pi. As a result, we do not recommend connecting external USB power to the Raspberry Pi while it is powered through the control board.
Backfeeding is not an issue with older Raspberry Pi versions, which do have a diode circuit on the USB power input. With Raspberry Pi versions prior to the Pi 3 B+, it is safe to have any combination of control board USB power, battery power, and Raspberry Pi USB power connected to the system.
The RPI5V pin provides direct access to the Raspberry Pi’s 5 V line, which comes from either the control board’s 5V supply or the Raspberry Pi’s USB power input (typically whichever is higher if both are connected). The 3.3 V output of the Raspberry Pi is also made available on the RPI3V3 pin.
Note that the diode circuit prevents power from being shared in the reverse direction: the Raspberry Pi cannot supply 5 V logic power to the control board through the 40-pin connector.
Power distribution
- VBAT is connected to the battery contact labeled BAT1+ and provides a direct connection to the battery supply.
- VRP provides access to the battery voltage after reverse-voltage protection.
- VSW is the battery voltage after reverse protection and the power switch circuit.
- VREG is the output of the on-board 5 V regulator.
- 5V is the output of the TPS2113A power multiplexer circuit which is connected to VREG by default, but switches to 5 V USB power if VREG is too low.
- 3V3 is the output of the 3.3 V LDO regulator.
See Section 3.6 for a diagram of the board’s power distribution buses and access points.
3.6. Expansion areas
The Romi 32U4 Control Board has several expansion areas (primarily in three groups near the front left and middle and back right edges) that break out all of the general-purpose I/O lines from the ATmega32U4 microcontroller and the Raspberry Pi. The board also provides access to various power inputs, outputs, and control pins, and it makes a few stand-alone buses available to help you make connections. The following diagrams identify the locations of these pins and the hardware associated with them; they are also available as a printable PDF (1MB pdf). For more information about the ATmega32U4 microcontroller and its peripherals, see Atmel’s ATmega32U4 documentation.
Pinout diagram of the Romi 32U4 Control Board (ATmega32U4 pinout, peripherals, and board power control). |
Pinout diagram of the Romi 32U4 Control Board (Raspberry Pi pinout, peripherals, and level shifters). |
Power distribution diagram of the Romi 32U4 Control Board. |
3.7. Raspberry Pi interface and level shifters
The Romi 32U4 Control Board was designed to be easy to interface with a Raspberry Pi single-board computer to expand the Romi’s processing power. It has a connector and mounting holes matching the Raspberry Pi HAT (Hardware Attached on Top) specification and is designed to connect to the Model B+ and newer versions of the Raspberry Pi with 40-pin GPIO headers (including the Raspberry Pi 3 Model B and Model A+). A 2×20-pin 0.1″ female header is soldered to the control board, and it ships with a set of four standoffs, screws, and nuts.
I²C communication
When used with a Raspberry Pi, the control board is designed to serve as an auxiliary controller, communicating with the Raspberry Pi using an I²C interface (also known as 2-wire Serial Interface, or TWI). As such, the ATmega32U4 microcontroller’s I²C data and clock lines (SDA and SCL) are connected to the corresponding lines on the Raspberry Pi’s I²C bus 1 through on-board level-shifting circuits. These bidirectional level shifters convert between the AVR’s 5 V logic level and the Raspberry Pi’s 3.3 V logic level.
We have written an Arduino library for our our 32U4 family of boards that lets them act as an I²C slave and provides a framework for communication between the ATmega32U4 and a Raspberry Pi master.
A tutorial on the Pololu blog demonstrates this library and its included example code, using them to make a robot that can be remotely controlled and monitored through a web server running on the Raspberry Pi.
General-purpose level shifters
In addition to the dedicated I²C level shifters, the board also makes available a few general-purpose level shifters that are not connected to any signals by default.
LS1 is a dual-channel unidirectional level shifter that converts a pair of 5 V inputs (HA and HB) to a pair of corresponding 3.3 V outputs (LA and LB).
LS2 and LS3 are each single-channel, tristatable, unidirectional level shifters. Each of these exposes four pins: OE (output enable), IN (input), OUT (shifted output), and VCC (logic supply voltage).
- When OE is high, OUT is in a high impedance state.
- When OE is low, OUT matches the state of IN, shifted to the voltage supplied on VCC.
For example, if you pull OE low, connect a 3.3 V signal to IN, and connect 5V to VCC, the signal will be shifted to 5 V logic level on OUT.
The input logic level can be 1.8 V to 5.5 V, while VCC (and the output logic level) can be 3 V to 5.5 V. The IN signal can have either a lower or higher logic level than the VCC voltage: you could connect a 5 V signal to IN and a 3.3 V to VCC or a 3.3 V signal to IN and a 5 V to VCC.
Powering the Raspberry Pi from the control board
The control board will provide 5 V power to an attached Raspberry Pi by default. See Section 3.5 for more details about how power is shared and can be controlled between the two boards.
ID EEPROM
The Romi 32U4 Control Board includes a 32-kilobit (4096-byte) EEPROM that connects to the Raspberry Pi’s ID_SD and ID_SC pins. The EEPROM ships with its contents blank, but you can program it as an ID EEPROM in the format specified by the Raspberry Pi HAT specifications, using the utilities provided there. When suitably programmed, the EEPROM can help the Raspberry Pi identify and configure itself to work with the Romi 32U4 Control Board.
Write protection for the EEPROM can be enabled by using solder to bridge the surface-mount jumper labeled “WP” next to the EEPROM chip. (The EEPROM is not write-protected by default.)
3.8. Pin assignments
The table below lists the most important pin assignments for the ATmega32U4 on the Romi 32U4 Control Board. This table is helpful if you want to add your own electronics to the Romi 32U4, write your own low-level code for interfacing with the hardware, or just want to understand better how the Romi 32U4 works. Each row represents a physical pin on the ATmega32U4.
The “Arduino pin names” column lists the names provided by the Arduino environment for the pin. These names can generally be used as arguments to any function that takes a pin number. However, there are some exceptions. For example, passing the number 4 to analogRead
actually reads pin A4, not pin 4. Also, due to hardware limitations, some functions only work on a limited set of pins.
The “Romi 32U4 functions” column documents what the pin is used for on the Romi 32U4 Control Board. Many pins can serve multiple purposes concurrently by switching modes. For example, PB0 can read the state of button C when it is an input, and it can control the red LED and serve as an LCD data line when it is an output.
ATmega32U4 pin name | Arduino pin names | Romi 32U4 Control Board functions | Notes/alternate functions |
PB7 | 11 | LCD control line (E) | Timer0 PWM output A (OC0A) Timer1 PWM output C (OC1C) UART flow control (RTS) Pin-change interrupt (PCINT7) |
PD4 | 4, A6, 24 | LCD control line (RS) | Analog input (ADC8) Timer1 input capture pin (ICP1) |
PB3 | 14, MISO | User pushbutton A LCD data line DB4 | SPI Master Input/Slave Output (MISO) Pin-change interrupt (PCINT3) ISP programming line (PDO) |
PB0 | 17, LED_BUILTIN_RX, SS | Red LED (RX) User pushbutton C LCD data line DB5 | SPI slave select (SS) Pin-change interrupt (PCINT0) |
PC7 | 13, LED_BUILTIN | Yellow LED LCD data line DB6 | Timer4 PWM output A (OC4A) Timer3 input capture pin (ICP3) Divided system clock output (CLKO) |
PD5 | 30, LED_BUILTIN_TX | Green LED (TX) User pushbutton B LCD data line DB7 | UART external clock (XCK1) UART flow control (CTS) |
PD7 | 6, A7, 25 | Buzzer PWM | Analog input (ADC10) Timer4 PWM output D (OC4D) Timer0 counter source (T0) |
PF6 | A1, 19 | Battery level input (VIN/3) | Analog input (ADC6) JTAG test data out (TDO) |
PB6 | 10, A10, 28 | Left Motor PWM | Analog input (ADC13) Timer1 PWM output B (OC1B) Timer4 PWM output B (OC4B) Pin-change interrupt (PCINT6) |
PB2 | 16, MOSI | Left motor direction | SPI Master Output/Slave Input (MOSI) Pin-change interrupt (PCINT2) ISP programming line (PDI) |
PB5 | 9, A9, 27 | Right motor PWM | Analog input (ADC12) Timer1 PWM output A (OC1A) Timer4 PWM output B (OC4B) Pin-change interrupt (PCINT5) |
PB1 | 15, SCK | Right motor direction | SPI Clock (SCK) Pin-change interrupt (PCINT1) ISP programming line (SCK) |
PB4 | 8, A8, 26 | Left encoder XORed input | Analog input (ADC11) Pin-change interrupt (PCINT4) |
PE2 | - | Left encoder input | Hardware bootloader select (HWB) |
PE6 | 7 | Right encoder XORed input | Analog comparator negative input (AIN0) External interrupt source (INT6) |
PF0 | A5, 23 | Right encoder input | Analog input (ADC0) |
PD0 | 3, SCL | I²C clock for Raspberry Pi communication and inertial sensors | Timer0 PWM output B (OC0B) External interrupt source (INT0) |
PD1 | 2, SDA | I²C data for Raspberry Pi communication and inertial sensors | External interrupt source (INT1) |
PD2 | 0 | Free I/O | UART receive pin (RXD1) External interrupt source (INT2) |
PD3 | 1 | Free I/O | UART transmit pin (TXD1) External interrupt source (INT3) |
PC6 | 5 | Free I/O | Timer3 PWM output A (OC3A) Timer4 PWM output A (OC4A) |
PD6 | 12, A11, 29 | Free I/O | Analog input (ADC9) Timer4 PWM output D (OC4D) Timer1 counter source (T1) |
PF7 | A0, 18 | Free I/O | Analog input (ADC7) JTAG test data in (TDI) |
PF5 | A2, 20 | Free I/O | Analog input (ADC5) JTAG test mode select (TMS) |
PF4 | A3, 21 | Free I/O | Analog input (ADC4) JTAG test clock (TCK) |
PF1 | A4, 22 | Free I/O | Analog input (ADC1) |
RESET | - | Reset pushbutton | internally pulled high, active low |
AREF | - | - | Analog reference |
3.9. Adding electronics
This section gives tips for how additional electronics can be connected to the Romi 32U4 Control Board.
Free I/O pins
If you want your additional devices to send or receive information from the AVR, you will need to connect them to one or more of the AVR’s I/O pins. The pin assignment table in Section 3.8 lists all of these pins and how they are used. Many of the I/O pins are already being used for some other purpose on the board, but there are 8 free I/O pins: 0, 1, 5, 12, A0, A2, A3, and A4. Any of the free I/O lines can be used as basic digital inputs or outputs; each pin also has some special capabilities.
Pin 0 (PD2) and pin 1 (PD3) are the RX and TX lines of the AVR’s TTL serial port.
Pin 5 (PC6) is a hardware PWM output and is usable with the Arduino analogWrite()
function. Pin 12 (A11/PD6) can also be used as a PWM output, but it is not supported by analogWrite()
, and using pin 12 for PWM might conflict with uses of pin 6 (which controls the buzzer by default) as these two pins are complementary outputs of Timer4 channel D.
Pins 12 (A11/PD6), A0 (18/PF7), A2 (20/PF5), A3 (21/PF4), and A4 (22/PF1) can be used as analog inputs.
Freeing up more I/O pins
If the free I/O pins are not sufficient for connecting the devices you want to connect, you might need to disable or disconnect some of the other features of the Romi 32U4 Control Board to free up more I/O pins.
If you do not need the AVR to be able to measure the battery voltage, you can use pin A1 (19/PF6) for other purposes. This pin can be used for digital input and output, as well as analog input. If you want to use this pin as a digital or analog input, you might need to cut the surface-mount jumper labeled “A1 = BATLEV” in order to disconnect it from the on-board voltage divider. If you only want to use A1 as an output, you might not need to cut that jumper.
If you are not connecting an LCD to the board’s LCD connector, then pin 11 (PB7) and pin 4 (A6/PD4) are free. Both pins can be used for digital input and output. In addition, pin 11 can be used as a PWM output and a pin change interrupt and pin 4 can be used as an analog input.
If you are not connecting an LCD to the board’s LCD connector, you can use the LCD contrast potentiometer for other purposes. The output of the potentiometer is a 0 V to 5 V signal which is accessible on the LCD connector. It can be connected to any free analog input if you want to read it from the AVR, or it might be useful to connect it to the other electronics that you are adding.
If you do not need to use the buzzer, you can free up pin 6 (A7/PD7) by cutting the surface-mount jumper labeled “6 = Buzzer”. Pin 6 can be used as a PWM output, digital I/O line, or analog input. Disabling the buzzer also frees up Timer4, which has several PWM output pins. These pins can be used as PWM outputs if they are not needed for their normal tasks.
If you do not need encoders, you can free up pin 7 (PE6), pin 8 (A8/PB4), PE2, and pin A5 (23/PF0). Each of those pins has a corresponding surface mount jumper on the bottom of the board that can be cut in order to disconnect the encoder output from the AVR.
Be careful about connecting electronics to pin 13 (PC7), pin 17 (PB0), and pin 30 (PD5). These pins are used to control the LEDs on the Romi 32U4. All three of these pins are controlled as outputs by the bootloader. Pin 17 (PB0) and pin 30 (PD5) are used as RX and TX indicators, so if you are sending or receiving data over USB then the Arduino USB code will drive those pins in its interrupt service routines while your sketch is running.
I²C devices
It should be possible to attach additional I²C slave devices to the control board’s I²C bus as long as the additional devices’ slave addresses do not conflict with that of the LSM6DS33, which uses 7-bit address 1101011. The ATmega32U4’s I²C pins (2 and 3) operate at 5 V. If you are connecting a 3.3 V device, you can connect it to the 3.3 V side of the bus instead (accessible through Raspberry Pi GPIO pins 2, for SDA, and 3, for SCL, even if a Raspberry Pi is not connected). Separate level shifters might be necessary to interface with devices that use other voltages.
If you do not want to use the inertial sensors on the I²C bus, you can cut the surface-mount jumpers labeled “IMU SDA Jmp” and “IMU SCL Jmp”. This frees up pin 2 (PD1) and pin 3 (PD0) for limited use as digital inputs and outputs as long as a Raspberry Pi is not attached to the control board. Note that the AVR’s I²C pins will remain connected to the on-board I²C level shifters and will therefore still be pulled up to 5 V.
Power
The control board’s power nodes are accessible in several areas on the board. If you power additional devices from VSW, then they will be powered whenever the control board’s power is in ON, and they will receive whatever voltage the batteries are outputting. If you power them from VREG, they will get 5 V power whenever the batteries are installed and the power is on (but they cannot be powered from USB). If you power them from a 5V pin, then they will receive 5V power whenever the control board’s logic components are powered. If you power them from 3V3, they will receive 3.3V power whenever the control board’s logic components are powered. For more information about these power nodes and how much current they can provide, see Section 3.5.
It is also possible to add your own power switch to control power to the Romi 32U4 Control Board, as described in Section 3.5.
Ground
You should make sure that all the grounds in your system are connected. The Romi 32U4 Control Board’s ground node can be accessed from pins labeled “GND”. It should be connected to the ground node of every other circuit board or device you add to the robot.
3.9.1. Controlling a servo
It is possible to modify the Servo library that comes with the Arduino IDE to use Timer 3 instead of Timer 1 with an ATmega32U4 based controller like the Romi 32U4. The modified Servo library does not interfere with Romi32U4Motors, making it possible to simultaneously control servos and the motors.
Warning: The modifications described here will affect any sketch for an ATmega32U4 based controller that uses the Servo library, including the Arduino Leonardo or A-Star.
- First, you will need to locate the Arduino IDE’s Servo library, and find the file inside it named ServoTimers.h. For the 1.6.x versions of the IDE, this file can be found in libraries/Servo/src/avr/ServoTimers.h. If you are using Mac OS X, you will need to right-click on the Arduino IDE icon and select “Show Package Contents” to see the files inside.
- Open ServoTimers.h in a text editor.
- Locate the following lines of code in ServoTimers.h:
#elif defined(__AVR_ATmega32U4__) #define _useTimer1 typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t ;
- The lower two lines of code specify that the library should use Timer 1. To use Timer 3 instead, just change
_useTimer1
to_useTimer3
and_timer1
to_timer3
. - Save the file.
The Arduino IDE will automatically incorporate your modifications to the Servo library. The next time you compile a sketch for an ATmega32U4 based controller that uses the Servo library, it will use Timer 3 instead of Timer 1.
3.10. AVR timers
- Timer0 is used by the Arduino environment for timing-related functions like
millis()
. - Timer1 is used by the Romi 32U4 Control Board Arduino library for driving motors.
- Timer3 is not used by the Romi 32U4 Arduino library and can be freely used for your own purposes.
- Timer4 is used by the Romi 32U4 Arduino library for controlling the buzzer. The buzzer pin (digital pin 6, or PD7; Timer4 output OC4D) can be freed for other uses by cutting the surface-mount jumper labeled “6 = Buzzer”.
3.11. Schematics and dimensions
Schematics
The schematic diagram for the Romi 32U4 Control Board is available as a PDF: Romi 32U4 Control Board schematic diagram (646k pdf).
Dimensions
A basic dimension diagram for the Romi 32U4 Control Board is available as a PDF: Romi 32U4 Control Board dimension diagram (604k pdf).
Dimensions that are not included in the above diagram can be measured from the following DXF, which shows the main board outline along with the sizes and locations of all of the holes on the board: Romi 32U4 Control Board drill guide (346k dxf).
The following picture shows the approximate dimensions of the Romi chassis which is intended to be used with the Romi 32U4 Control Board:
Basic dimension diagram of the Romi Chassis. |
Control board additions
Most of the hardware on the Romi 32U4 Control Board consists of surface-mount components that are already soldered to the board, but there are a few through-hole parts that you need to solder yourself.
- Solder the buzzer to the top of the control board, matching its orientation to the printed outline, then trim the excess length from the buzzer leads underneath the board.
- Solder the two 1×6 low profile female headers for the encoders to the board. One female header should be soldered on each side in the set of through-holes that matches to the orientation you will use when soldering the corresponding male headers to the Romi Encoder Pair Kit. We recommend using the set closer to the edges of the Romi 32U4 Control Board.
- Optional: If you plan to use an LCD (not included) with the control board, solder either the 2×7 female or 2×7 male LCD header to the set of pins labeled “LCD” in the center of the control board. We generally recommend soldering the female connector to the board and the male connector to the LCD if you do not have some particular reason for doing it the other way.
- Optional: If you plan to connect other headers or wires, consider soldering them now.
It is still possible to solder the buzzer and LCD header after the control board has been mounted on the chassis, but soldering them beforehand is easier and avoids the risk of inadvertently melting the chassis with your soldering iron. The control board must be removed from the chassis before the encoder headers can be soldered in.
The four battery contact terminals should be soldered to the control board after it is mounted on the chassis, as described in the chassis assembly instructions. You will be able to remove the board and battery contacts from the chassis as a single piece after soldering.
Assembling the chassis
Once the through-hole components are soldered to the Romi 32U4 Control Board, please follow the instructions given in the Pololu Romi Chassis User’s Guide to finish assembling the chassis, mounting the control board, and soldering in the battery contacts.
The Romi 32U4 Control Board is designed to be programmed over USB from the Arduino IDE. It can be programmed from Windows, Linux, and Mac OS X. The ATmega32U4 on the control board comes preloaded with the same USB bootloader as the A-Star 32U4 family of general-purpose programmable ATmega32U4 boards. The following sections will help you get started programming your Romi 32U4 Control Board.
If you use Windows XP, you will need to have either Service Pack 3 or Hotfix KB918365 installed before installing the A-Star drivers. Some users who installed the hotfix have reported problems that were solved by upgrading to Service Pack 3, so we recommend Service Pack 3 over the hotfix.
- Download the A-Star Windows Drivers (7k zip) and extract the ZIP file to a temporary folder on your computer. (These files are also available in the “drivers” directory from the A-Star repository on GitHub.)
- Open the “a-star-windows” folder. Right-click on “a-star.inf” and select “Install”.
- Windows will ask you whether you want to install the drivers. Click “Install” (Windows 10, 8, 7, and Vista) or “Continue Anyway” (Windows XP).
- Windows will not tell you when the installation is complete, but it should be done after a few seconds.
COM port details
If you are using Windows 10 or later and choose not to install the drivers, the A-Star will still be usable. To tell which “USB Serial Device” in your Device Manager is the A-Star, double-click on each one and look at the “Hardware Ids” property in the “Details” tab. An A-Star running a sketch will have the ID USB\VID_1FFB&PID_2300&MI_00
, while an A-Star in bootloader mode will have the ID USB\VID_1FFB&PID_0101
Getting the prerequisites
avr-gcc -v avr-objcopy -V make -v avrdude
Compiling an example program
#define F_CPU 16000000 #include <avr/io.h> #include <util/delay.h> int main() { DDRC |= (1 << DDC7); // Make pin 13 be an output. while(1) { PORTC |= (1 << PORTC7); // Turn the LED on. _delay_ms(500); PORTC &= ~(1 << PORTC7); // Turn the LED off. _delay_ms(500); } }
PORT=\\\\.\\GLOBALROOT\\Device\\USBSER000 MCU=atmega32u4 CFLAGS=-g -Wall -mcall-prologues -mmcu=$(MCU) -Os LDFLAGS=-Wl,-gc-sections -Wl,-relax CC=avr-gcc TARGET=main OBJECT_FILES=main.o all: $(TARGET).hex clean: rm -f *.o *.hex *.obj *.hex %.hex: %.obj avr-objcopy -R .eeprom -O ihex $< $@ %.obj: $(OBJECT_FILES) $(CC) $(CFLAGS) $(OBJECT_FILES) $(LDFLAGS) -o $@ program: $(TARGET).hex avrdude -p $(MCU) -c avr109 -P $(PORT) -U flash:w:$(TARGET).hex
Make sure that the PORT variable in the Makefile is the name of the device’s virtual serial port. In Windows, \\\\.\\GLOBALROOT\\Device\\USBSER000
should work if the A-Star is the only USB device connected that is using the usbser.sys driver, but you can change it to be the actual name of the COM port (e.g. COM13
In a command prompt, navigate to the directory with the Makefile and main.c. If you run the command make
, the code should get compiled and produce a file named “main.hex”.
Programming
To program the A-Star device, you will need to get it into bootloader mode first. One way to do this is to reset the AVR twice within 750 ms. Most of the boards in our 32U4 family have a reset button that can be used to reset the board. On any of our 32U4 family of boards, a pushbutton can be connected between the GND and RST pins to serve as a reset button, or you can use a wire. Once the device is in bootloader mode, quickly run the command make program
to program it. If you wait longer than 8 seconds, the A-Star bootloader will exit and the AVR will go back to running the user program.
The Romi 32U4 Control Board can be programmed from the Arduino IDE as described in the preceding sections.
To help interface with all the on-board hardware on the control board, we provide the Romi32U4 library. The Romi32U4 library documentation provides detailed information about the library, and the library comes with several example sketches.
- In the Arduino IDE, open the “Sketch” menu, select “Include Library”, then “Manage Libraries…”.
- Search for “Romi32U4”.
- Click the Romi32U4 entry in the list.
- Click “Install”.
- Download the latest release archive from GitHub and decompress it.
- Rename the folder “romi-32u4-arduino-library-master” to “Romi32U4”.
- Move the “Romi32U4” folder into the “libraries” directory inside your Arduino sketchbook directory. You can view your sketchbook location by opening the “File” menu and selecting “Preferences” in the Arduino IDE. If there is not already a “libraries” folder in that location, you should make the folder yourself.
- After installing the library, restart the Arduino IDE.
After you install the Romi32U4 library, you can learn more about it by trying the included example sketches and by reading the Romi32U4 library documentation.
If you are using the Romi 32U4 Control Board with a Raspberry Pi, you might also want to make use of our Raspberry Pi slave library for Arduino, which sets up the A-Star as an I²C slave and helps establish communication with a Raspberry Pi master. See Section 3.7 for more information about the Raspberry Pi interface.
7. The Romi 32U4 USB interface
The Windows 10 Device Manager in “Devices by connection” mode, showing that the A-Star is a composite device. |
On a Linux computer, you can see details about the USB interface by running lsusb -v -d 1ffb:
in a Terminal. The virtual serial port can be found by running ls /dev/ttyACM*
in a Terminal.
On a Mac OS X computer, the virtual serial port can be found by running ls /dev/tty.usbmodem*
in a Terminal.
8. The A-Star 32U4 Bootloader
The A-Star 32U4 Bootloader is based on the Caterina bootloader, which is the bootloader used on the Arduino Leonardo, Arduino Micro and several other ATmega32U4 boards. The bootloader is open source and its source code is available on GitHub. The bootloader occupies the upper four kilobytes of the ATmega32U4’s program memory, leaving 28 KB for the user program. The bootloader’s USB interface consists of a single virtual serial port that accepts the programming commands defined in AVR109. The bootloader always runs first immediately after the AVR is reset.
Startup logic
The main difference between the A-Star 32U4 Bootloader and Caterina is in the startup logic. This is the part of the bootloader that runs immediately after the AVR is reset, and it decides whether to run the user program or run the rest of the bootloader. The startup logic of the Caterina bootloader is designed so that when the RST line goes low, the bootloader will run. This means that if you want to restart your program using the RST line, it will take 8 seconds before the bootloader times out waiting for an upload and the sketch starts.
The A-Star 32U4 Bootloader has different startup logic that allows you to use the RST line to reset the board with a smaller delay. If the RST line goes low once, the user program will run after a 750 ms delay. If the RST line goes low twice within 750 ms, then the bootloader will run. (This behavior is the same as on boards like SparkFun’s Pro Micro.)
The startup logic for the A-Star 32U4 bootloader. |
Brown-out detection
Unlike many other ATmega32U4 boards, our 32U4 family of boards have brown-out detection enabled. The brown-out threshold is 4.3 V, and if the voltage on VCC goes below this then the AVR will reset. The bootloader was designed so that the user program can detect brown-out resets. To do so, check to see if the BORF bit in the MCUSR register is set, and then clear it later. Here is some example code you could put in your setup
function for detecting brown-out resets:
pinMode(13, OUTPUT); if (MCUSR & (1 << BORF)) { // A brownout reset occurred. Blink the LED // quickly for 2 seconds. for(uint8_t i = 0; i < 10; i++) { digitalWrite(13, HIGH); delay(100); digitalWrite(13, LOW); delay(100); } } MCUSR = 0;
9. Reviving an unresponsive Romi 32U4
9.1. Reviving using the Arduino IDE
Reset button
Resetting the board twice within 750 ms makes the board go into bootloader mode. The bootloader will exit after 8 seconds and try to run the sketch again if it has not started receiving programming commands. To revive the device, you need to make sure you start sending it programming commands before the 8-second period is over.
The substitute port method
- Connect a substitute serial port device to your computer. This should be a device that is recognized by the Arduino IDE as a serial port, but it should not be an A-Star 32U4, Arduino Leonardo, Arduino Micro, or any other device that disappears and reappears as a new device when a piece of software like the Arduino IDE opens the port, sets the baud rate to 1200, and then closes the port. It should also be a device that will not cause any problems if it receives data from the Arduino IDE. Here are some examples of substitute serial port devices:
- A USB-to-serial adapter such as the CP2102N
- A Pololu USB AVR Programmer v2.1
- An Arduino Uno R3
- A non-USB serial port such as
/dev/ttyS0
on a Raspberry Pi
- Connect the 32U4 device to your computer via USB.
- In the “Tools” menu, open the “Board” sub-menu and select “Pololu A-Star 32U4”.
- In the “Tools” menu, open the “Port” sub-menu and select the substitute serial port.
- Click the Upload button. The Arduino IDE will compile your sketch and start uploading it.
- As soon as the box near the bottom of the IDE says “Uploading…”, reset the board twice to get into bootloader mode.
- In the “Tools” menu, open the “Port” sub-menu and check to see if any ports are selected. If the “Port” menu is grayed out or no ports in it are selected, that is good, and you can skip to step 6.
- Reset the board twice to get the board into bootloader mode. While the board is in bootloader mode, quickly select the new serial port that corresponds to the bootloader in the “Port” menu.
- After 8 seconds, the bootloader will exit and attempt to run the sketch again. Wait for the bootloader to exit. Verify that either the “Port” menu is grayed out or no ports in it are selected.
This method has been tested on Arduino 2.0.3 but the timing requirements of the last step are so tight that the method might be impossible on slower computers.
- In the “Tools” menu, open the “Board” sub-menu and check to see if the “Pololu A-Star 32U4 (bootloader port)” entry is visible. If this entry is visible, you can skip to step 6.
- Using a text editor, open the file named boards.txt that provides the “Pololu A-Star” board entries. In Windows, you can typically find this file in %LocalAppData%\Arduino15\packages\pololu-a-star\hardware\avr\. In Linux, you can typically find this file in ~/.arduino15/packages/pololu-a-star/hardware/avr/. On macOS, you can typically find this file in ~/Library/Arduino15/packages/pololu-a-star/hardware/avr/. If you installed the boards manually instead of using the Board Manager, you can find it in [sketchbook location]/hardware/pololu/avr.
- In the boards.txt file that you opened, find the lines at the bottom of the file that start with
#a-star32U4bp
. Uncomment each of those lines by deleting the “#” character, and then save the file. - Close the Arduino IDE and restart it.
- In the “Tools” menu, open the “Board” sub-menu and select “Pololu A-Star 32U4 (bootloader port)”. This entry is configured so that the Arduino IDE will send programming commands directly to selected serial port, instead of trying to send a special USB command to the port to get it into bootloader mode and then waiting for the new port to appear. By selecting this entry, the timing of the programming process below becomes easier, especially on Windows.
- Prepare the computer to show you a list of its virtual serial ports. If you are using Windows, this means you should open the Device Manager. If you are on Linux or macOS, this means you should open a Terminal and type the command
ls /dev/tty*
but do not press enter until the board is in bootloader mode in the next step. - Reset the board twice to get the board into bootloader mode. While it is in bootloader mode, quickly look at the list of serial ports provided by your operating system in order to determine what port the bootloader is assigned to.
- In the Arduino IDE, click the “Verify” button to compile your sketch. This could make the timing easier during the next step.
- Reset the board twice to get the board into bootloader mode again. As soon as the yellow LED starts fading in and out, indicating the board is in bootloader mode, quickly select the serial port of the bootloader in the Arduino IDE (in Tools > Port) and then quickly click the Upload button.
This method can also work in the older Arduino 1.8.19 with some modifications. You should select the correct port in the Port menu prior to the last step (e.g. by temporarily putting the board into bootloader mode and then selecting it). This makes the timing of the last step easier because you can just click the “Upload” button instead of clicking three times to select a port. Also, if the timing of the last step is still too tight, you can actually click Upload before putting the board into bootloader mode, but you need to get the board into bootloader mode while the IDE is still compiling, before the upload phase begins. (Neither of these optimizations are possible on Arduino 2.0.3 because it erases your serial port selection if the port disappears.) However, if you are using Arduino 1.8.19, the uploading-before-bootloader method documented above is probably easier.
9.2. Reviving using AVRDUDE
- Connect the device to your computer via USB.
- Prepare the computer to show you a list of its virtual serial ports. If you are using Windows, this means you should open the Device Manager. If you are on Linux or Mac OS X, this means you should open a Terminal and type the command
ls /dev/tty*
but do not press enter until the board is in bootloader mode in the next step. - Press the reset button twice within 750 ms to make the AVR go into bootloader mode. You should see the yellow LED fading in and out when the AVR is in bootloader mode. While it is in bootloader mode, quickly look at the list of serial ports provided by your operating system in order to determine what port the bootloader is assigned to.
- Type the following command in your terminal and replace COM4 with the name of the bootloader’s serial port, but do not press enter yet. This command will erase the malfunctioning program on the device but preserve the bootloader.
- Quickly run the command you typed previously. The command needs to be run within 8 seconds of starting the bootloader, or else the bootloader will exit and try to run the malfunctioning program again.
10. Related resources
To learn more about using the Romi 32U4 Control Board, see the following list of resources:
- The Arduino IDE has many examples that can run on the Romi 32U4 Control Board (although note that the control board’s on-board hardware might conflict with some of these examples).
- The Romi 32U4 Control Board uses the same microcontroller as the Arduino Leonardo and Arduino Micro, so you can search the Internet for relevant projects and code examples that use one of those boards.
- Atmel’s ATmega32U4 documentation has the ATmega32U4 datasheet and many related documents.
- AVR Libc Home Page: this page documents the standard library of functions that you can use with GNU C and C++ compilers for the AVR.
- Romi 32U4 Arduino library
- Romi 32U4 library documentation
- LUFA – the Lightweight USB Framework for AVRs
- WinAVR
- Microchip Studio for AVR and SAM Devices
- AVRDUDE
- AVR Freaks
Datasheets for some of the components found on the Romi 32U4 Control Board are available below:
- ATmega32U4 documentation
- Texas Instruments DRV8838 motor driver datasheet (1k redirect)
- ST LSM6DS33 3D accelerometer and 3D gyro module datasheet (1MB pdf)
- Texas Instruments TPS2113A power multiplexer datasheet (1k redirect)
Finally, we would like to hear your comments and questions on the Pololu Robotics Forum!
