8. Reviving an unresponsive A-Star
8.1. Reviving using the Arduino IDE
8.2. Reviving using AVRDUDE
  • You accidentally loaded a malfunctioning program onto the device that is incapable of responding to the special USB command. For example, your program might be stuck in an infinite loop with interrupts disabled.
  • You loaded a program which uses a non-standard type of USB interface or no USB interface.
