Support » Sample Project: Wixel USB Joystick »
2. Materials and Tools
Beyond the Wixel, you will need a suitable input device to convert. We used a Tandy Deluxe Joystick for this tutorial, but any device that uses pushbuttons, switches, and/or potentiometers for input will probably work.
The Tandy Deluxe Joystick in its original form. |
The tools and supplies you require will probably depend on your particular situation, but might include:
- Screwdrivers
- Soldering iron and solder
- Diagonal cutter
- Wire stripper
- Some wire for making connections to the Wixel
- Double-sided foam tape or hot glue gun
- USB cable, A to Mini-B
Many of the tools are available in the Tools section of the Pololu web site.
