Support » Pololu AVR C/C++ Library User’s Guide »
4. Using the Pololu AVR Library for your own projects
<p>After getting one of the example projects to work with an Orangutan controller or 3pi robot, you can start working on more complicated programs of your own. The library provides easy access to all of the features of the Orangutans and 3pi, including the LCD screen, buttons, LEDs, motors, and buzzer. There are also functions in the library that make it easy for you to do more general-purpose operations with the AVR, such as timing and analog-to-digital conversion. The library also provides support for the <a href="/product/961">Pololu QTR sensors</a> and the <a href="/product/1217">Pololu Wheel Encoders</a> (it should actually work for quadrature encoders in general). For a complete list of functions provided by the library, see the <strong><a href="/docs/0J18">command reference</a></strong>.</p>
<p>Usually, the easiest way to adapt this code to your own projects will be to start with a working example and gradually add the things that you need, one step at a time. For Microchip Studio users, we recommend using the New Project templates installed by the library, which are documented in the <a href="/docs/0J51">Pololu AVR Programming Quick Start Guide</a>. However, if you want to start from scratch, there are just a few things that you need to know. First, to use the library with C, you must place one of the following lines</p>
<h4>C</h4>
<pre>#include <pololu/orangutan.h>
#include <pololu/3pi.h>
#include <pololu/qtr.h>
#include <pololu/encoders.h></pre>
<p>at the top of any C file that uses functions provided by the library. To use the library with C++, the equivalent lines are</p>
<h4>C++</h4>
<pre>#include <pololu/orangutan>
#include <pololu/Pololu3pi.h>
#include <pololu/PololuQTRSensors.h>
#include <pololu/PololuWheelEncoders.h></pre>
<p>The line or lines that you include depend on which product you are using with the library.</p>
<p>Second, when compiling, you must link your object files with the appropriate <code>libpololu_atmegaX.a</code> file. This is accomplished by passing the <code>-lpololu_atmegaX</code> option to <code>avr-gcc</code> during the linking step, where <code>X</code> can be <code>48</code>, <code>168</code>, <code>328p</code>, <code>324p</code>, <code>644p</code>, <code>1284p</code>, or <code>1284p_x2</code>.</p>
<p>To add the <code>-lpololu_atmegaX</code> option within AVR Studio 4, select <strong>Project > Configuration Options > Libraries</strong>. You should see <code>libpololu_atmega48.a</code>, <code>libpololu_atmega168.a</code>, <code>libpololu_atmega328p.a</code>, <code>libpololu_atmega324p.a</code>, <code>libpololu_atmega644p.a</code>, <code>libpololu_atmega1284p.a</code>, and <code>libpololu_atmega1284p_x2.a</code> listed as options in the left column. Select the file that matches the microcontroller you are programming and click “add library” to add it to your
project.</p>
<p><strong>Note:</strong><ul><li>3pi robots with serial numbers less than <strong>0J5840</strong> use the ATmega168 microcontroller; 3pi robots with serial number 0J5840 or greater use the ATmega328P microcontroller.</li><li>Original Orangutan X2s use the ATmega644P microcontroller; new X2s use the ATmega1284P microcontroller and require you link the <strong>libpololu_atmega1284p_x2.a</strong> library file.</li><li>The Orangutan SVP-1284 requires you link the <strong>libpololu_atmega1284p.a</strong> library file.</li></ul></p>
<table class="picture_with_caption center wide"><tr><td style="max-width: 614px"><img alt="" class="wide" data-gallery-pictures="[{"id":"0J1160","caption":"\u003cp\u003eAVR Studio 4 library settings for using the Pololu AVR library (libpololu).\u003c/p\u003e","url_tiny":"https://a.pololu-files.com/picture/0J1160.98x98.jpg?c45bb688cadc3bb23c9691074561d5c5","url_medium":"https://a.pololu-files.com/picture/0J1160.600x480.jpg?c45bb688cadc3bb23c9691074561d5c5","url_full":"https://a.pololu-files.com/picture/0J1160.1200.png?c45bb688cadc3bb23c9691074561d5c5","longest_side":614}]" data-picture-id="0J1160" data-picture-longest_side="614" src="https://a.pololu-files.com/picture/0J1160.614.png?c45bb688cadc3bb23c9691074561d5c5" /></td><p></tr><tr><th style="max-width: 614px"><p>AVR Studio 4 library settings for using the Pololu AVR library (libpololu).</p></th></tr></table></p>
<p>Finally, we also strongly recommend the linker option <code>-Wl,-gc-sections</code>. This causes unused library functions to not be included, resulting in a much smaller code size. To include this in AVR Studio 4, select <strong>Project > Configuration Options > Custom Options</strong>. Click on [Linker options] and add <code>-Wl,-gc-sections</code> to the list. This linker option is included in both the AVR Studio and Linux-based example programs described earlier.</p>
<table class="picture_with_caption center wide"><tr><td style="max-width: 614px"><img alt="" class="wide" data-gallery-pictures="[{"id":"0J1159","caption":"\u003cp\u003eRecommended AVR Studio 4 linker options for projects using the Pololu AVR Library.\u003c/p\u003e","url_tiny":"https://a.pololu-files.com/picture/0J1159.98x98.jpg?79e5b739e5cc05bbacd345cb6264a3a7","url_medium":"https://a.pololu-files.com/picture/0J1159.600x480.jpg?79e5b739e5cc05bbacd345cb6264a3a7","url_full":"https://a.pololu-files.com/picture/0J1159.1200.png?79e5b739e5cc05bbacd345cb6264a3a7","longest_side":614}]" data-picture-id="0J1159" data-picture-longest_side="614" src="https://a.pololu-files.com/picture/0J1159.614.png?79e5b739e5cc05bbacd345cb6264a3a7" /></td><p></tr><tr><th style="max-width: 614px"><p>Recommended AVR Studio 4 linker options for projects using the Pololu AVR Library.</p></th></tr></table></p>
<h4>Special option necessary for Orangutan X2</h4>
<p>If you are using one of the newer Orangutan X2s that comes with a ATmega1284p processor, you must define the <code>_X2_1284</code> preprocessor macro so that the Pololu AVR Library Header files know that you are programming an X2 rather than an Orangutan SVP-1284. To include this in AVR Studio 4, select <strong>Project > Configuration Options > Custom Options</strong>. Click on [All files] and add: <code>-D_X2_1284</code>. This compilation option is included in both the AVR Studio and Linux-based example programs for the Orangutan X2 1284.</p>
<table class="picture_with_caption center wide"><tr><td style="max-width: 614px"><img alt="" class="wide" data-gallery-pictures="[{"id":"0J2968","caption":"\u003cp\u003eThis picture shows how to configure AVR Studio 4 to use the -D_X2_1284 option, which is required when compiling a program a newer Orangutan X2 that has a ATmega1284p.\u003c/p\u003e","url_tiny":"https://a.pololu-files.com/picture/0J2968.98x98.jpg?ba7b29365fdddd2b314ea9c8bca45b43","url_medium":"https://a.pololu-files.com/picture/0J2968.600x480.jpg?ba7b29365fdddd2b314ea9c8bca45b43","url_full":"https://a.pololu-files.com/picture/0J2968.1200.png?ba7b29365fdddd2b314ea9c8bca45b43","longest_side":614}]" data-picture-id="0J2968" data-picture-longest_side="614" src="https://a.pololu-files.com/picture/0J2968.614.png?ba7b29365fdddd2b314ea9c8bca45b43" /></td><p></tr><tr><th style="max-width: 614px"><p>This picture shows how to configure AVR Studio 4 to use the -D_X2_1284 option, which is required when compiling a program a newer Orangutan X2 that has a ATmega1284p.</p></th></tr></table></p>
