3. Getting Started
3.a. Motor and Power Connections
3.b. Signal Connections
3.c. Jumper Settings
3.d. LED Feedback
3.e. Automatic Calibration for Your RC/Analog Controller
TReX input/output connection points
Getting started with your TReX can be as simple as connecting power, your motors, and your RC or analog control signals (see Section 3.a and Section 3.b). Configure your jumpers for RC or analog mode (see Section 3.c) and you’re good to go. While it’s running, the TReX will communicate with you via its LEDs (see Section 3.d). Once you have all your connections in place, we recommend your first step be to calibrate your TReX for your particular RC or analog controller (see Section 3.e).
Pololu TReX Dual Motor Controller DMC01
