macOS bug affecting the A-Star 32U4 Bootloader
There is a bug in macOS 10.15.1 that prevents it from using the A-Star 32U4 Bootloader. Unfortunately, this means that you will be unable to program an A-Star 32U4, Zumo 32U4, Balboa 32U4, or Romi 32U4 from a computer running macOS 10.15.1. The bug is probably present in macOS 10.15.0 too. macOS 10.15 is also known as macOS Catalina, and was released in October 2019.
If you see a large number of error messages like the ones below, then the bug is probably happening:
avrdude: ser_recv(): read error: Device not configured
avrdude: butterfly_recv(): programmer is not responding
avrdude: ser_drain(): read error: Device not configured
avrdude: ser_send(): write error: Device not configured
This bug is fixed in macOS 10.15.2, so we recommend upgrading to the latest version of macOS if you encounter this bug.
New Products
ACS72981KLRATR-150U5 Current Sensor Compact Carrier 0A to 150A, 5V
12V, 100mA Step-Down Voltage Regulator D45V1E2F12
ACS72981LLRATR-100U3 Current Sensor Large Carrier 0A to 100A, 3.3V
CT432-HSWF50MR TMR Current Sensor Large Carrier -50A to +50A, 5V
ACS72981LLRATR-100B3 Current Sensor Compact Carrier -100A to +100A, 3.3V
Pololu Ideal Diode Reverse Voltage Protector, 4-60V, 10A
5V, 500mA Step-Down Voltage Regulator D45V5F5
1.4-7V, 3.8A Fine-Adjust Step-Down Voltage Regulator D30V33MAL
ACS72981LLRATR-050B5 Current Sensor Compact Carrier -50A to +50A, 5V
ACS72981ELRATR-200B3 Current Sensor Large Carrier -200A to +200A, 3.3V
