Support » User’s guide for the Robot Arm Kit for Romi »
1. Contents
Kit contents
The Robot Arm Kit for Romi consists of the following items:
- One Micro Gripper with Position Feedback Servo
- One micro servo with position feedback
- One top micro gripper case
- One bottom micro gripper case
- One micro gripper plate
- One micro gripper pinion gear
- Two micro gripper paddles with rack
- One Romi expansion platform
- One main arm
- One rear tilt arm
- One front tilt arm
- One pivot stand
- Two servo mounting brackets
- One short linkage
- Two pivot transfer linkages
- One tilt servo horn
- One lift servo horn
- One alternate tilt servo horn attachment
- One alternate life servo horn attachment
- Two standard-sized servos with position feedback
- Six 20 mm nylon spacers, 4 mm OD, 2.7 mm ID
- Three 6 mm nylon spacers, 4 mm OD, 2.7 mm ID
- Two 1.5″ aluminum standoffs, #2-56 thread, M-F
- Two 1″ aluminum standoffs, #2-56 thread, M-F
- Six 1″ #2-56 Machine screws
- Three 3/8″ #2-56 machine screws
- Four 1/4″ #2-56 machine screws
- Thirteen #2-56 hex nuts
- Nine #2 washers
- Six 8 mm M3 machine screws
- Six M3 hex nuts
