Support » Pololu Dual G2 High-Power Motor Driver Shields for Arduino User’s Guide »
3. Included components
This motor driver board ships with all of the surface-mount parts populated. However, soldering is required for assembly of the included through-hole parts. The following through-hole parts are included:
Pololu Dual G2 High-Power Motor Driver 18v18 Shield for Arduino with included hardware. |
- one extended/stackable 1×10 female header (for assembly as an Arduino shield)
- two extended/stackable 1×8 female headers (for assembly as an Arduino shield)
- two extended/stackable 1×6 female headers (for assembly as an Arduino shield)
- three 2-pin 5mm terminal blocks (for board power and motor outputs)
- 40-pin 0.1″ straight breakaway male header (may ship in several pieces, such as two 20-pin strips)
- one 0.1″ shorting block (for optionally supplying shield power to Arduino)
