Support » Pololu Romi 32U4 Control Board User’s Guide »
7. The Romi 32U4 USB interface
The Windows 10 Device Manager in “Devices by connection” mode, showing that the A-Star is a composite device. |
On a Linux computer, you can see details about the USB interface by running lsusb -v -d 1ffb:
in a Terminal. The virtual serial port can be found by running ls /dev/ttyACM*
in a Terminal.
On a Mac OS X computer, the virtual serial port can be found by running ls /dev/tty.usbmodem*
in a Terminal.
