Support »
3pi Robot Videos
- 1. Introductory Videos: Using the 3pi Robot
- 2. Line Following
- 3. Maze Solving
- 4. 3pi Robots With Additional Electronics
- 5. Project Tabletop Videos
Pololu Introduction to the 3pi Robot
3pi Demo from the Maker Shed
“Full Shape” 3pi from Cytron Technologies
2. Line Following
3pi Exhibition at LVBots Challenge 4.0
The following unedited video shows six 3pi prototypes running simultaneously on the same line-race course. Each robot was programmed independently, but as you can see, the results were remarkably consistent. The last one on the line wins!
3pi Spinning Line Follower (by Byon)
Byon wrote a program that turns the 3pi into a spinning line follower that blinks its red LED every time it’s over the front part of the line. This isn’t the fastest line follower out there, but it is one of the most original. You can find his code here and use it to make your own spinning line follower! Note that the code requires the Pololu AVR library.
Fast Line Follower on a Small Course
IceFlinger shows off his fast 3pi line follower. It is running the sample PID line-following code provided by Pololu with improved PID constants so that it can hold the line while going around sharp turns at high speed. He won the event he entered at the 2009 Eastern Canada Robot Games competition.
Desktop Entertainment
MonkeyFCoconut writes: “My desk at work makes for a nice canvas to put down some black tape and make a line following robot track. I’ve wanted to do this for years, and just finally broke down and bought an awexome robot to play with. This robot is powered ‘logically’ by the ATMega328p processor, which is nice if you are familiar with Arduino projects.”
Tech Fest 3pi Line Follower (by RoboticsProfessor)
For pictures and information, please see the San Diego Tech-Fest, Winter 2009 web site.
Speeding Up on Straightaways (by leenstl)
3pi (No-MOD) Robot Laser Pointer Follower (by Jason)
Jason has programmed his 3pi to follow a laser pointer rather than a line. He started a forum thread about his project and provides his source code for those who want to try it for themselves. The only additional hardware required is a laser pointer.
Waiter Robot
Waiter Robot can make a “Robot Bar” for your next exhibition, show, private event, or sales promotion. They use the 3pi to deliver food and drinks in an remarkable way. March 2011.
Large 3pi Line-following Course
Video of a large, white-on-black 3pi line-following course from Osamu Iwasaki’s Vimeo channel.
3. Maze Solving
Pololu Optimized Line-Maze Solver
This is a demonstration of a 3pi maze-solving robot that was programmed by a Pololu engineer to compete in LVBots Challenge 4.0. The code running on this 3pi prototype—it has only one blue power LED on the bottom—is more advanced (and complicated) than the sample maze-solving code we provide. Improvements over the sample program include a higher base running speed with better-tuned line-following PID constants, faster and smoother turns, and increased speed on long straight segments.
Tech Fest 3pi Line-Maze Solver (by RoboticsProfessor)
Flood-Fill Line-Maze Solver for Looped Mazes
Lufamseed programmed his 3pi with a flood-fill algorithm that allows it find the shortest path through a looped maze. A looped maze is one that has internal cycles that can thwart a standard left- or right-hand-on-the-wall strategy by causing the robot to loop endlessly around the cycle or to miss entire sections of the maze. Flood-filling requires the robot to treat the maze as a grid of possible intersections; it populates this grid as it traverses the maze and at every step it floods the maze starting from a particular, known cell. Flooding the maze assigns values to every reachable cell based on how long it would take to reach that cell through known paths, which lets the robot deduce the shortest path from its current location to the cell the flood originated from. This algorithm can require a lot of memory, so storing data compactly is a must when implementing it on the 3pi.
Roboglia 2010 Regional Round
Karandex’s 3pi maze-solver won this competition (in Maharashtra, India) with a time of 6 seconds. This video shows both the winning 3pi and the second-place finisher, which took 16 seconds to solve the same maze. This is a stock 3pi running optimized code.
Maze Solver From Any Location
Moat’s 3pi line tracking robot solves the maze from any starting point. First, the robot learns the entire maze. Then, the robot may be placed anywhere. Once it figures out where it is, it goes straight to the end. The code is available here.
Collective Control of m3pi Robots
This project used m3pi robots with Wixels attached for wireless communication. It used a Java program which calculates optimum routes for each robot and schedules them. The scheduling process is based on the A*-algorithm. To avoid deadlocks and collisions it uses automata, theory and a Java API called Supremica developed at Chalmers University of Technology in Gothenburg Sweden.
Line Following With Gaps and Obstacles
This 3pi robot, customized and programmed by Jan Matas, can follow a black line with sharp corners, gaps, and obstacles. The text translates to: “We have seen many robots that try to follow a black line. And how have they performed? Sadly… But today, the revolution is here. Hello my name is Pololu 3pi. I am the robot preparing for Robocup jr. 2010 in category rescue.”
3pi as a Wall-Following Robot
This video shows a 3pi robot that uses two Sharp distance sensors to follow walls on its left and drive around obstacles in its way. Please see our sample project for information on how to make your own 3pi wall follower.
3pi Pool Racer at LVBots Challenge 4.5
This competition pits multiple robots against each other on the same course. The goal is to be the fastest to complete three laps around the obstacles.
Radio-Controlled 3pi
This video shows a 3pi robot being controlled via signals from a two-channel RC receiver. Please see our sample project for more information on how to make your own RC 3pi.
3pi Fire Fighter
This video, uploaded by myblack60impala, shows the first place entrant in the St. Louis Robotics FIRE mini comp, a small scale fire fighting competition.
Collision-Avoiding 3pis
This video shows a school project by Group 9 at University West (Trollhättan, SWEDEN) in fall 2009. The 3pis use Sharp distance sensors to simultaneously run on the same line and maze courses without colliding.
Another Wall-Following 3pi
This video shows the final version of a school project to turn a 3pi robot into a wall follower using two side-looking long-range sharp distance sensors and a front-looking sonar sensor. For more information, please see Mathew’s 3pi blog, which tracks the progress of the project and provides source code and pictures.
Home-made m3pi Controlled by Bluetooth Keyboard
Kazuhiro Ouchi mounts an ARM mbed development board on a 3pi expansion board and uses it to receive commands from a Bluetooth keyboard and send serial commands to a serial-slave 3pi. He wrote an mbed notebook page (in Japanese).
Micromouse 3pi
Terry, also known as lufamseed, made this Micromouse 3pi robot by that uses distance sensors and encoders along with a flood-fill algorithm to find the shortest path through a walled maze.
Walled Maze Solver 3pi
Brian Jones made this walled maze solver 3pi robot using distance sensors.
3pi Sound Follower
Louie used three electret microphones and two 74HC4052 multiplexers to turn his 3pi into a sound follower. To find out more about his project, see Louie’s forum thread.
Remote-controlled 3pi
MrDreamBot made this remote-controlled 3pi that uses Wixels and custom PC software written in Java.
Human Use of Human Beings
An art display of many line-following, networked Pololu 3pi Robots.
Project Tabletop is a series of interesting, customer-created open source projects for the 3pi robot, including barcode reading, grid navigation, and obstacle avoidance.
