2. Laser-engraved wood handgun case
Laser engraving is a great way to personalize anything, including a handgun case, as shown here.
We raster-engraved this walnut handgun case using the red “Colt” logo shown below. During raster engraving, the laser burns away a very thin layer of material to create a recessed area in the specified shape. Since the laser is burning the material, the wood might get darker or even charred depending on the type of wood and any stains, glues, or other chemicals that have been applied to the wood. In this case, the laser roughened the surface a bit but did not leave it looking charred.
If you are concerned about charring, you can always start by having us engrave a small sample, first. You might also be able to remove some of the charring by sanding. Note that many plastics including acrylic/Plexiglas do not char from the laser
Image file used to laser-engrave a wooden handgun case.
When laser engraving a prefabricated piece such as this handgun case, we align the engraving by eye; although the logo might look well-centered, it could be off by a few millimeters (or even more) in any direction, depending on the details. Alignment is not an issue if we are also laser cutting the edges of the part.
Please also see our example of laser-cut wood, which also illustrates some laser charring. To get started with laser cutting your own parts, see our custom laser cutting service page.
New Products
20.4:1 Metal Gearmotor 25Dx65L mm HP 24V with 48 CPR Encoder
4.4:1 Metal Gearmotor 25Dx48L mm HP 24V
120:1 Mini Plastic Gearmotor HP, Offset 3mm D-Shaft Output, with 12 CPR Encoder, Back Connector
24V, 50mA Isolated Step-Up Voltage Regulator U5Z9F24
