Support » Basic LEGO Robot »
4. BASIC Stamp II Software
(In this section, we go over the major features of the program. For more details, view the entire program (3k bs2). Note that the pin numbers used in the program correspond to the schematic diagram in section 3, above.)
The BASIC Stamp makes serial I/O very straightforward with its serout
instruction. A typical use of the instruction is:
serout MC_SOUT, 32, [$80, 0, LFWD, SPEED] 'Left motor forward at SPEED
The first value,
MC_SOUT, specifies the serial output pin to use, which is P10 in our example.
The second argument, 32, specifies the settings for the serial output; we use
32 because it specifies the baud rate to be 19,200, which is the maximum rate at
which the motor controller can receive. The four values in square brackets
are the values sent out over the serial line.
The first two values sent to the motor controller are always hex 80 (128 in decimal) and 0, which let the motor controller know that it is being issued a command. The third value specifies the motor number and direction. To help prevent mistakes with this third parameter, we defined constants for forward and backward for our two motors at the beginning of our program:
LFWD con 0 LBAK con 1 RFWD con 2 RBAK con 3
(Of course, which constant gets assigned which number depends on how your robot is wired up and what you call forward and reverse or left and right.) The final parameter in the 4-byte sequence is the speed at which the motor should run, where 0 stops the motor and 127 (7F hex) is full speed.
Note:
At the beginning of the program, it is important to reset the motor
controller. Make sure the serial line is high
before you reset the motor controller:
high MC_SOUT ’serial line idle state low MC_RESET ’reset motor controller high MC_RESET |
The main loop of the program is rather simple since the robot
does not do much. For simplicity, we use the pause
instruction to determine the time that the robot backs up or turns,
but the BASIC Stamp could potentially be doing something more useful
during that time.
loop: 'Go forward till bump something serout MC_SOUT, 32, [$80, 0, LFWD, SPEED] 'Left and right motors forward at SPEED serout MC_SOUT, 32, [$80, 0, RFWD, SPEED] '32 indicates 8 bits, no parity, non-inverted, ' buad rate 19200 if (RBUMP = 0) then rbumped 'If bumped, turn backward in appropo direction if (LBUMP = 0) then lbumped goto loop rbumped: 'Turn backward right, then spin left in place for a random time serout MC_SOUT, 32, [$80, 0, LBAK, SPEED] 'Turn backward for 1 sec serout MC_SOUT, 32, [$80, 0, RBAK, SLOWSPEED] pause 1000 serout MC_SOUT, 32, [$80, 0, LBAK, SPEED] 'Spin in place for random time, TURNTIME serout MC_SOUT, 32, [$80, 0, RFWD, SPEED] random TURNTIME pause (TURNTIME*5) + 250 'pause between 0.25 and 1.5 seconds goto loop lbumped: 'Turn backward left, then spin right in place for a random time serout MC_SOUT, 32, [$80, 0, LBAK, SLOWSPEED] serout MC_SOUT, 32, [$80, 0, RBAK, SPEED] pause 1000 serout MC_SOUT, 32, [$80, 0, LFWD, SPEED] serout MC_SOUT, 32, [$80, 0, RBAK, SPEED] random TURNTIME pause (TURNTIME*5) + 250 goto loop
For more details, view the entire program (3k bs2). Note that the pin numbers used in the program correspond to the schematic diagram above.
