Support » Basic LEGO Robot »
2. Materials and Tools
Here are the essential parts you will need if you want to build a similar robot. Except for the LEGO chassis, these items are available either from Pololu or from most electronic component distributors.
- Pololu micro dual serial motor controller
- BASIC Stamp II from Parallax
- Small, differential-drive chassis
- Two long-lever, snap-action switches for use as bumper switches
- Small solderless breadboard
- Two 10k resistors for use as pull-ups for the bumper switches
- 9V battery and battery snap
- Hook-up wire
- Power switch
You might also need these basic tools to prepare you chassis:
- Diagonal cutters
- Wire strippers
- Soldering iron and solder
- Hot glue gun
