Support » Sample Project: 3pi Wall Follower »
4. Software
Insert fresh batteries into your 3pi and use an AVR ISP programmer (like our USB AVR programmer) to program your 3pi with the following code. For information on programming your 3pi please visit the programming your 3pi section of the 3pi robot user’s guide.
/* * 3pi-wall-follower - demo code for the Pololu 3pi Robot * * If two Sharp distance sensors ( http://www.pololu.com/catalog/product/136 ) * are installed, this code will allow a 3pi to explore its environment by * following objects it finds on its left side. * * http://www.pololu.com * http://forum.pololu.com * */ // The 3pi include file must be at the beginning of any program that // uses the Pololu AVR library and 3pi. #include <pololu/3pi.h> // This include file allows data to be stored in program space. The // ATmegaxx8 has 16x more flash than RAM, so large // pieces of static data should be stored in program space. #include <avr/pgmspace.h> // Introductory messages. The "PROGMEM" identifier causes the data to // go into program space. const char welcome_line1[] PROGMEM = " Pololu"; const char welcome_line2[] PROGMEM = "3\xf7 Robot"; const char name_line1[] PROGMEM = "Wall"; const char name_line2[] PROGMEM = "Follower"; // A couple of simple tunes, stored in program space. const char welcome[] PROGMEM = ">g32>>c32"; const char go[] PROGMEM = "L16 cdegreg4"; // Refresh the LCD display every tenth of a second. const int display_interval_ms = 100; #define MS_ELAPSED_IS(n) (get_ms() % n == 0) #define TIME_TO_DISPLAY (MS_ELAPSED_IS(display_interval_ms)) void initialize() { // Set PC5 as an input with internal pull-up disabled DDRC &= ~(1<< PORTC5); PORTC &= ~(1<< PORTC5); // Play welcome music and display a message print_from_program_space(welcome_line1); lcd_goto_xy(0,1); print_from_program_space(welcome_line2); play_from_program_space(welcome); delay_ms(1000); clear(); print_from_program_space(name_line1); lcd_goto_xy(0,1); print_from_program_space(name_line2); delay_ms(1000); // Display battery voltage and wait for button press while(!button_is_pressed(BUTTON_B)) { clear(); print_long(read_battery_millivolts()); print("mV"); lcd_goto_xy(0,1); print("Press B"); delay_ms(100); } // Always wait for the button to be released so that 3pi doesn't // start moving until your hand is away from it. wait_for_button_release(BUTTON_B); clear(); print("Go!"); // Play music and wait for it to finish before we start driving. play_from_program_space(go); while(is_playing()); } void back_up() { if (TIME_TO_DISPLAY) { clear(); lcd_goto_xy(0,0); print("Backing"); lcd_goto_xy(0,1); print("Up"); } // Back up slightly to the left set_motors(-50,-90); } void turn_in_place() { if (TIME_TO_DISPLAY) { clear(); lcd_goto_xy(0,0); print("Front"); lcd_goto_xy(0,1); print("Obstacle"); } // Turn to the right in place set_motors(50, -50); } int main() { // set up the 3pi initialize(); int last_proximity = 0; const int base_speed = 200; const int set_point = 100; // This is the "main loop" - it will run forever. while(1) { // In case it gets stuck: for 1 second every 15 seconds back up if (get_ms() % 15000 > 14000) { back_up(); continue; } // If something is directly in front turn to the right in place int front_proximity = analog_read(5); if (front_proximity > 200) { turn_in_place(); continue; } int proximity = analog_read(7); // 0 (far away) - 650 (close) int proportional = proximity - set_point; int derivative = proximity - last_proximity; // Proportional-Derivative Control Signal int pd = proportional / 3 + derivative * 20; int left_set = base_speed + pd; int right_set = base_speed - pd; set_motors(left_set, right_set); if (TIME_TO_DISPLAY) { clear(); lcd_goto_xy(0,0); print_long(proximity); lcd_goto_xy(5,0); print_long(pd); lcd_goto_xy(0,1); print_long(left_set); lcd_goto_xy(4,1); print_long(right_set); } last_proximity = proximity; // remember last proximity for derivative } // This part of the code is never reached. A robot should // never reach the end of its program, or unpredictable behavior // will result as random code starts getting executed. If you // really want to stop all actions at some point, set your motors // to 0,0 and run the following command to loop forever: // // while(1); }
