5. Materials
5.1. More information about acrylic
We can laser cut plastics, woods, metals, rubbers, foams, and papers. We can handle some materials up to 1" thick, but the maximum thickness varies depending on the material. We stock some materials including acrylic, birch plywood, MDF, mild and stainless steel, aluminum, ABS, Delrin, and more. For a complete list of the materials we stock, and available thicknesses and colors, see our quote request form. You are also welcome to supply your own material for us to cut.
Materials we can laser cut
Here is a list of the materials that we can cut. If you do not see your material listed, we would be happy to try cutting it as long as it does not contain vinyl. To test a new material, please submit a quote request and provide details about your material in the special instructions section of the quote request form.
Type Material Max Thickness UV-printable Notes
Plastics ABS 1/4″ ✓ Smells very bad when cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell. It is machine-friendly and will not break or crack easily if dropped or hit. It has a hair-cell textured front surface, which hides fingerprints and scuffs well. The backside of the material is smooth and glossy, and since ABS does not come with masking, this surface is prone to scratches and markings.
Acetal/Delrin 1/4″ ✘ Has smooth, glossy surfaces that often have scratches on them. Delrin is a very tough, slippery material that resists warping and deforming well and is commonly used to make gears. Its slick surface makes it difficult to adhere to without sanding, so we cannot UV-print onto it. It is the most expensive plastic that we carry.
Acrylic 1″ ✓ Also known as Plexiglas, Lucite, PMMA. Our favorite material to work with – cuts cleanly with a laser-polished edge. See the More information about acrylic section for more details.
HDPE 1/16″ ✘ Edges melt badly and produce a lot of dust that sticks to the parts when cut.
Kapton 0.050″ ✘ Chars badly when cut, cutting adhesive-backed sheets increases the charring, and also causes the parts to be sticky.
Mylar 0.010″ ✘ Also known as Polyester film.
Nylon 1/16″ ✘ Edges melt, smell, and discolor badly when cut.
PETG 1/8″ ✓ Smells very bad when cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell. PETG is not brittle, so parts do not crack or break easily. PETG comes with a film masking on both sides to protect the surface during the cutting process, but the edges still tend to melt and turn yellow from the laser cutting.
Polyethylene 1/8″ ✘ Melts badly when cut.
Polypropylene 1/8″ ✘ Melts somewhat when cut
Styrene 1/8″ ✓ Smells very bad when cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell. Edges melt somewhat.
Teflon 1/8″ ✘ Melts somewhat when cut.
Metals Aluminum 1/4″ ✓ Blemishes and light scratches may affect the surfaces of metal parts. Laser cutting metals may cause slight discoloration, dross formation, and burring. Typically, burring is minimal for metals under 1/8″ thick, but is more severe for thicker pieces. We do not offer any post-cutting services such as deburring, tumbling, polishing, bending, welding, anodizing, or coating (other than UV printing). We ship parts as cut.
Brass 1/8″ ✓
Bronze 1/8″ ✓
Mild Steel 1/4″ ✓
Spring Steel 1/4″ ✓
Stainless Steel 1/4″ ✓
Woods Birch Ply 1″ ✓ A popular, eco-friendly plywood that is great for laser cutting. It is typically cut without masking, but can be masked to minimize burn markings for an additional fee.
MDF 1″ ✓ Low-cost material to laser cut. Does not come with protective masking, so surfaces will have some discolorations and burn markings from cutting.
Rubbers NBR (Buna-N) 3/32″ ✘ Laser cutting rubbers typically generates a lot of char/soot. We ship parts as cut without dusting or cleaning them.
FKM/Viton 1/8″ ✘
Neoprene 1/16″ ✘
Polyethylene 1/8″ ✘
Silicone 1/8″ ✘
Foams Depron 1″ ✓ Laser cutting foams typically generates some light char/soot around part edges. We ship parts as cut without dusting or cleaning them. The edges typically have a concave profile after cutting. How deep the concave shape extends depends on several factors, but a good way to prevent problems is to avoid having areas that are narrower than the thickness of the material.
EPDM 1″ ✘
Neoprene 1″ ✘
Nylon 1″ ✘
Polyethylene 1″ ✘
Polyurethane 1″ ✘
Silicone 1/8″ ✘
Others Cardboard 5/32″ ✓ Has a slight smell to it when laser cut.
Cardstock / Paper ✓ Can be laser cut, but it is usually more cost-effective to plot/die cut it instead. Edges might show light burn marks, depending on the material color (dark colors hide the markings better).
Fabrics ✘ We have cut various types of fabrics including acrylic, canvas, cordura, cotton, nylon, polyester, and wool, and have not had any trouble. Edges become cauterized (which helps prevent the fabric from fraying), but might have slight discoloration depending on the color.
Leather 1/8″ ✘ All leather (both natural and synthetic) smells very bad when laser cut, so you might have to air the parts out once you receive them. Synthetic leather MUST be vinyl-free. Edges will have noticeable char/soot on them.
Materials we cannot laser cut
We do not or cannot cut the following materials:
Material Notes
✘ Carbon Fiber
✘ Copper For copper parts, or other metals that are not included in the list of we metals we can cut, please consider our friends at OSH Cut.
✘ Glass
✘ PCB We cannot cut printed circuit board materials such as FR-4, G-10 (garolite), and others.
✘ Polycarbonate Difficult to laser cut, and burns very badly. Consider PETG or impact-modified acrylic instead.
✘ PVC Also commonly known as Cintra – contains vinyl, which releases toxic fumes.
✘ Vinyl We do not cut any materials that contain vinyl since it releases toxic fumes.
How to supply your own material for laser cutting
If you plan to supply material the material for your order, please mention this in the special instructions section in our quote request form and be sure to include the sheet size. When sending material:
  • Please wait until after you have received your quote before you ship it (in case we cannot cut that material, or your design, etc.).
  • Make sure to include your name and quote number with the shipment.
  • Make sure the material is flat, as warped or bowed materials can cause problems during cutting. Some materials, like rubbers and fabrics, can be shipped rolled since they will still lay flat right away, while others can take a very long time to flatten out.
  • Do not ship material that is longer than 48″ unless it can be cut down using scissors or you have made special arrangements with us for larger pieces.
  • You can have suppliers ship directly to us to avoid having to pay an extra shipping charge.
  • You are responsible for supplying any extra material needed to recut parts that do not come out well (we cover this when using our stock material).
  • Please let us know what you would like us to do with the leftover material. We can hold it for another order in the near future, discard it, or send it to you along with your order (an additional shipping charge might be required).
Suppliers for laser-cutting materials
Here is a list of suppliers we and our customers work with frequently:
Laser material details
Plastics
ABS (acrylonitrile butadiene styrene)
Max thickness 1/4″ (6.4 mm)
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✘
Stocked thicknesses 1.5 mm (0.06″)
3.0 mm (0.12″)
4.5 mm (0.18″)
6.0 mm (0.24″)
Stocked layout sizes 12″×12″ (30×30 cm)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
32″×48″ (81×122 cm)
Stocked colors black
Masking added on request
Surface texture haircell and smooth
(see notes)
Surface finish glossy
(see notes)
Opacity opaque
Notes:
  • ABS has good elasticity and toughness, so it can bend a lot before cracking or breaking, and it will not crack or break easily if dropped or impacted.
  • It is easily machined with hand tools.
  • Our stocked ABS has a haircell textured front surface, which hides fingerprints and scuffs well. The backside of the material is smooth and glossy, but since it does not come with masking, this surface is prone to scratches and markings. We might be able to special order ABS that with smooth surfaces on both sides on request.
  • We can UV print on both the smooth and haircell surfaces, but UV printing does not cover up the haircell texture. We expect most prints will look better on the smooth side and will print there by default unless you specify otherwise.
  • ABS smells very bad when laser cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell.
Acetal/Delrin®
UV-printable ✘
Stocked ✓
RoHS 3 ✓
Stocked thicknesses 3/64″ (1.2 mm)
1/16″ (1.6 mm)
1/8″ (3.2 mm)
3/16″ (4.8 mm)
1/4″ (6.4 mm)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
Stocked colors black and white
Surface texture smooth
Opacity opaque (black)
translucent (white)
Notes:
  • Acetal, is also know as Polyoxymethylene (POM) or by the brand name Delrin®.
  • Acetal is a very rigid, tough, and slippery material that resists new warping and deformation well, but we often receive and cut parts from large sheets with slight warping which can be difficult to flatten.
  • It has smooth, glossy surfaces that often have scratches since it does not come with masking.
  • The slick surfaces are difficult to adhere to without sanding.
  • Acetal and is commonly used to make gears.
  • Acetal is the most expensive plastic that we stock.
Acrylic
Max thickness 1″ (25.4 mm)
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 Clear sheets only
(see notes)
Stocked thicknesses 0.75 mm (0.03″)
1.5 mm (0.06″)
3.0 mm (0.12″)
4.5 mm (0.18″)
5.6 mm (0.22″)
6.0 mm (0.24″)
9.0 mm (0.35″)
12.0 mm (0.47″)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
see notes for more info
Stocked colors see the More information
about acrylic
section
Masking film or paper
matte
mirror
faux brushed metal
Opacity transparent
opaque
translucent
mirror
Notes:
  • Acrylic, also known as Plexiglas®, Lucite, and PMMA (polymethyl methacrylate), is our favorite material to work with.
  • RoHS compliance documentation for colored acrylic sheets are generally unavailable due to constantly changing pigment materials.
  • For more in-depth information on acrylic, please see the More information about acrylic section.
  • We usually stock larger sheets of common colors (black, white, and clear). Large sheets of other acrylic colors can sometimes be special ordered, but may have expensive freight costs.
  • Two-tone acrylics are typically only available up to 24″×48″ (61×122 cm).
HDPE (high density polyethylene)
Max thickness 1/16″ (1.6 mm)
UV-printable ✘
Stocked ✘
Notes:
  • HDPE edges melt badly and produce a lot of dust that sticks to the parts when cut.
Kapton
Max thickness 0.050″ (1.3 mm)
UV-printable ✘
Stocked ✘
Notes:
  • Kapton is also known as polyimide film.
  • Kapton chars badly when cut. Cutting adhesive-backed sheets increases the charring, and also causes the parts to be sticky.
Mylar
Max thickness 0.010″ (0.25 mm)
UV-printable ✘
Stocked ✓
RoHS 3 ✓
Stocked thicknesses 0.003″ (0.08 mm)
0.004″ (0.10 mm)
0.005″ (0.13 mm)
0.010″ (0.25 mm)
Stocked layout sizes see notes
Stocked colors clear
Opacity transparent
Notes:
  • Mylar is also known as polyester film.
  • This is the same material used as transparency sheets with overhead projectors.
  • We cut stocked Mylar from 40″ (102 cm) wide rolls, so the largest layout we can cut from stocked material 39.5″ × 47.5″ (100 × 121 cm).
  • Also available with adhesive backing through suppliers like McMaster-Carr.
Nylon
UV-printable untested
Primer recommended
for UV printing
untested
Stocked ✘
Notes:
  • Nylon edges melt, smell, and discolor badly when cut.
PETG (polyethylene terephthalate glycol)
Max thickness 1/8″ (3.2 mm)
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✓
3.0 mm (0.12″)
Stocked layout sizes 24″×48″ (61×122 cm)
Masking film
Opacity transparent
Notes:
  • PETG has good elasticity, so it can bend a lot before cracking or breaking.
  • PETG smells very bad when cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell.
  • The edges tend to melt and turn yellow from laser cutting even though sheets come with a film masking on both sides.
PE (polyethylene)
UV-printable ✘
Stocked ✘
Notes:
  • PE melts badly when cut.
PP (polypropylene)
UV-printable ✘
Stocked ✘
Notes:
  • PP melts somewhat when cut.
Styrene
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✘
Stocked thicknesses 0.030″ (0.76 mm)
1.5 mm (0.06″)
3.0 mm (0.12″)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
Stocked colors white
Surface finish matte
Opacity opaque
Notes:
  • Styrene and has good elasticity, so it can bend a lot before cracking or breaking.
  • Styrene smells very bad when cut, so you might have to wash or air out the parts out upon receiving them to get rid of the smell.
  • Its edges melt somewhat when cut.
  • Styrene is not as glossy as acrylic.
Teflon
UV-printable ✘
Stocked ✘
Notes:
  • Teflon melts somewhat when cut.
Metals
General notes about metals:
  • We can typically cut metal alloys other than just the ones we stock.
  • Other than UV printing, we do not offer any post-cutting services such as deburring, tumbling, polishing, bending, welding, anodizing, or coating. We ship parts as cut.
    • Blemishes and light scratches may affect the surfaces of metal parts.
    • Laser cutting metals may cause slight discoloration, dross formation, and burring. Typically, burring is minimal for metals under 1/8″ thick, but is more severe for thicker pieces.
Aluminum
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
Stocked alloys/types 5052, 6061
RoHS 3 ✓
Stocked thicknesses 0.032″ (0.81 mm)
0.040″ (1.0 mm)
0.050″ (1.3 mm)
0.063″ (1.6 mm)
1/8″ (3.2 mm)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
Stocked colors natural
Masking not available
Surface finish unpolished/mill
Opacity opaque
Magnetic ✘
Notes:
Brass
UV-printable ✓
Primer recommended
for UV printing
Stocked ✘
Magnetic ✘
Bronze
UV-printable ✓
Primer recommended
for UV printing
Stocked ✘
Magnetic ✘
Mild steel
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
Stocked alloys/types 1018
RoHS 3 ✓
0.060″ (1.5 mm)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
Opacity opaque
Magnetic ✓
Notes:
  • The 1018 steel we stock is also commonly called mild steel, low-carbon steel, or cold-rolled steel.
  • 1018 steel is easily weldable, formable, and machinable.
  • Some rust might affect the surface of mild steel parts, and they are vulnerable to further rust or corrosion.
  • See our general notes about metals.
Through-cutting, vector etching, and raster engraving on mild steel.
Spring steel
UV-printable ✓
Primer recommended
for UV printing
Stocked ✘
Magnetic depends on alloy/type
Notes:
Through-cutting, vector etching, and raster engraving on spring steel.
Stainless steel
UV-printable ✓
Primer recommended
for UV printing
Stocked ✓
Stocked alloys/types 304
RoHS 3 ✓
Stocked thicknesses 0.024″ (0.61 mm)
0.030″ (0.76 mm)
0.036″ (0.91 mm)
0.048″ (1.2 mm)
0.060″ (1.5 mm)
12″×24″ (30×61 cm)
24″×24″ (61×61 cm)
24″×48″ (61×122 cm)
Surface finish #2B unpolished/mill
#3 brushed
#4 brushed
Opacity opaque
Magnetic ✘
(see notes)
Notes:
  • The 304 stainless steel we stock is strong and weldable.
  • Stainless steel parts are resistant to corrosion and rust.
  • 304 stainless steel is not magnetic, but there are other types of stainless steel that are.
Through-cutting, vector etching, and raster engraving on stainless steel.
Woods
General notes about woods:
  • We strongly recommend adding masking to minimize burn markings and discoloration from laser cutting.
  • Primer is usually unnecessary for UV printing on wood since it is porous, though you can still add it to maximize adhesion strength.
Birch plywood
UV printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✓
Stocked thicknesses 1/16″ (1.6 mm)
1/8″ (3.2 mm)
1/4″ (6.4 mm)
3/8″ (9.5 mm)
1/2″ (12.7 mm)
Stocked layout sizes 30″×24″ (76×61 cm)
30″×48″ (76×122 cm)
Surface texture/finish natural
Opacity opaque
Notes:
  • Birch plywood is a popular, eco-friendly plywood that is great for laser cutting.
  • Stocked 1/8″ and thicker sheets are BB/BB grade.
  • Small patches, light mineral streaks, and tight pin knots might affect both surfaces of the wood.
  • The thickness of stocked sheets varies significantly.
  • See our general notes about woods.
MDF (medium-density fiberboard)
UV printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✓
Stocked thicknesses 1/8″ (3.2 mm)
1/4″ (6.4 mm)
1/2″ (12.7 mm)
Surface finish natural
Opacity opaque
Other materials
Cardboard
Max thickness 5/32″ (3.97 mm)
UV printable ✓
Primer recommended
for UV printing
Stocked ✓
RoHS 3 ✓
Stocked thicknesses 5/32″ (3.97 mm)
Stocked layout sizes 40″x48″ (16×19 cm)
Stocked colors natural (brown)
Notes:
  • Cardboard has a slight smell when laser cut.
  • Primer is usually unnecessary for UV printing on cardboard since it is porous, though you can still add it to maximize adhesion strength.
  • Corrugated cardboard sheets have a fluted center layer that makes bending/folding parts easier when the fold line is parallel to the flute direction. If that is important for your parts, please specify the flute direction in your file.
    • For the cardboard we stock, the flutes are parallel with the 40″ edges.
Cardstock/paper
Max thickness
UV printable ✓
Primer recommended
for UV printing
Stocked ✘
Notes:
  • We can laser cut cardstock and paper, but it is usually more cost-effective to plot/die cut it instead.
  • Laser cutting cardstock/paper might leave light burn marks. Darker colors are better at hiding burn marks.
Fabrics
Max thickness
UV printable ✘
Stocked ✘
Notes:
  • We have successfully laser cut various types of fabrics including acrylic, canvas, cordura, cotton, nylon, polyester, and wool.
  • Edges of laser cut fabrics become cauterized (which helps prevent the fabric from fraying), but might have slight discoloration depending on the color.
  • Fabric can be sent on a roll to avoid wrinkling.
Leather
UV printable ✘
Stocked ✘
Notes:
  • Synthetic leathers must be vinyl-free.
  • All leather (both natural and synthetic) smells very bad when laser cut, so you might have to air the parts out once you receive them.
  • Edges of laser cut leather will have noticeable char/soot on them. We ship parts as cut without dusting or cleaning them.
Custom Laser Cutting Service
