5. PWM-Based Motor Control Code
#include <avr/io.h>
// Motor Control Functions -- pwm is an 8-bit value
//  (i.e. ranges from 0 to 255)
void M1_forward(unsigned char pwm)
  OCR0A = 0;
  OCR0B = pwm;
void M1_reverse(unsigned char pwm)
  OCR0B = 0;
  OCR0A = pwm;
void M2_forward(unsigned char pwm)
  OCR2A = 0;
  OCR2B = pwm;
void M2_reverse(unsigned char pwm)
  OCR2B = 0;
  OCR2A = pwm;
// Motor Initialization routine -- this function must be called
//  before you use any of the above functions
void motors_init()
	// configure for inverted PWM output on motor control pins:
	//  set OCxx on compare match, clear on timer overflow
	//  Timer0 and Timer2 count up from 0 to 255
	TCCR0A = TCCR2A = 0xF3;
	// use the system clock/8 (=2.5 MHz) as the timer clock
	TCCR0B = TCCR2B = 0x02;
	// initialize all PWMs to 0% duty cycle (braking)
	OCR0A = OCR0B = OCR2A = OCR2B = 0;
	// set PWM pins as digital outputs (the PWM signals will not
	// appear on the lines if they are digital inputs)
	DDRD |= (1 << PORTD3) | (1 << PORTD5) | (1 << PORTD6);
	DDRB |= (1 << PORTB3);
The following sample program demonstrates how these motor control functions can be used:
#define F_CPU 20000000  // system clock is 20 MHz
#include <util/delay.h>  // uses F_CPU to achieve us and ms delays
// delay for time_ms milliseconds by looping
//  time_ms is a two-byte value that can range from 0 - 65535
//  a value of 65535 (0xFF) produces an infinite delay
void delay_ms(unsigned int time_ms)
	// _delay_ms() comes from <util/delay.h> and can only
	//  delay for a max of around 13 ms when the system
	//  clock is 20 MHz, so we define our own longer delay
	//  routine based on _delay_ms()
	unsigned int i;
	for (i = 0; i < time_ms; i++)
		_delay_ms(1);
int main()
	motors_init();
	M1_forward(128);  // motor 1 forward at half speed
	M2_reverse(25);  // motor 2 reverse at 10% speed
	delay_ms(2000);  // delay for 2s while motors run
	M1_reverse(64);  // motor 1 reverse at 25% speed
	M2_forward(0);  // motor 2 stop/brake
	// loop here forever to keep the program counter from
	//  running off the end of our program
	while (1)
	return 0;
TB6612FNG Dual Motor Driver Carrier
Pololu 3pi Robot
