Support » Application Note: Using the Motor Driver on the 3pi Robot and Orangutan Robot Controllers »
3. Simple Code to Drive the Motors
If we don’t want to worry about variable motor speed, we can simply make use of the truth table values in the previous section to figure out how to drive our motors. The code to do this becomes simple AVR digital I/O manipulation:
Initialize the motor control pins
#include <avr/io.h> // use Data Direction Registers (DDRx) to // set the four motor control pins as outputs DDRD |= (1 << PORTD3) | (1 << PORTD5) | (1 << PORTD6); DDRB |= (1 << PORTB3);
Motor 1 forward at full speed
PORTD &= ~(1 << PORTD5); // drive pin PD5 low PORTD |= (1 << PORTD6); // drive pin PD6 high
Motor 1 reverse at full speed
PORTD |= (1 << PORTD5); // drive pin PD5 high PORTD &= ~(1 << PORTD6); // drive pin PD6 low
Motor 1 brake low
PORTD |= (1 << PORTD5) | (1 << PORTD6); // drive pins PD5 and PD6 high
Motor 2 forward at full speed
PORTD &= ~(1 << PORTD3); // drive pin PD3 low PORTB |= (1 << PORTB3); // drive pin PB3 high
Motor 2 reverse at full speed
PORTD |= (1 << PORTD3); // drive pin PD3 high PORTB &= ~(1 << PORTB3); // drive pin PB3 low
Motor 2 brake low
PORTD |= (1 << PORTD3); // drive pin PD3 high PORTB |= (1 << PORTB3); // drive pin PB3 high
To achieve variable speeds, we can rapidly alternate between driving and braking a motor, but doing this in software can be taxing on the CPU. Fortunately, AVRs come with hardware timers that can rapidly toggle the motor driver states for us while leaving the CPU free for our higher-level computations.
