4.c. Sequencer
The Sequence tab in the Maestro Control Center.
The Sequence tab allows simple motion sequences to be created and played back on the Maestro. A sequence is simply a list of “frames” specifying the positions of each of the servos and a duration (in milliseconds) for each frame. In version 1.6.0.0 and later of the software, each frame of a sequence also contains speed and acceleration values for each servo, but these values are not used by default (see the “Speed and acceleration” subsection below). Sequences are stored in the registry of the computer where the sequence was created. Sequences can be copied to the script, which is saved on the Maestro. Sequences can also be exported to another computer via a saved settings file.
To begin creating a sequence, click the New Sequence button and enter a name for the sequence. Using the controls in the Status tab, set each of the servos to the position you would like for the first frame, then click Save Frame at the bottom of the window. Repeat to create several frames, then switch back to the Sequence tab. You can now play back the sequence using the Play Sequence button, or you can set the servos to the positions of a specific frame by clicking the Load Frame button.
The Frame properties… button allows you to set the duration and name of a frame.
The Save Over Current Frame button overwrites the selected frame(s) with the current target values from the Maestro.
If the Play in a loop checkbox is checked, sequence playback will loop back to the beginning of the sequence whenever it reaches the end.
The Sequence dropdown box along with the Rename, Delete, and New Sequence buttons allow you to create and manage multiple sequences.
A sequence can also be used to create a script which is stored on the Maestro. There are two buttons for copying the sequence into the script:
  • Copy Sequence to Script sets the script to a looped version of the sequence. In most cases, you will also want to check the “Run script on startup” option in the Script tab so that the script runs automatically when the Maestro is powered up, enabling fully automatic operation without a connection to a computer.
  • Copy all Sequences to Script is an advanced option that adds a set of subroutines to the end of the current script. Each subroutine represents one of the sequences; calling the subroutine from the script will cause the sequence to be played back a single time. These subroutines must be used together with custom script code; for example, you could make a display in which a button connected to an input channel triggers a sequence to play back.
To control the speed and acceleration values used by your servos while a sequence is playing, you can simply set those values in the “Channel settings” tab and click “Apply Settings”.
Alternatively, the Use saved speed & acceleration checkbox allows different frames to have different speeds and accelerations. This settings specifies that when you play back a sequence, load a saved frame, or generate a script, the speed and acceleration values stored in each frame should be applied to the servos before each servo is commanded to move to its saved position. This setting is a property of the sequence, so you can decide which sequences will behave this way. This setting does not affect how sequences are recorded or saved in your computer: it only affects how they are played back.
Sequence Editing Tips
  • You can select multiple frames by holding down the Ctrl or Shift buttons while clicking on them. This allows you to quickly move, delete, set the duration of, cut, copy, or save over several frames at once.
  • You can drag any of the tabs out of the main window in to their own windows. If you drag the Sequence tab out of the window then you will be able to see the Status tab and the Sequence tab at the same time.
  • You can cut, copy, and paste frames by selecting them and then using the Copy Frame and Paste Frame buttons, the Edit menu or the standard keyboard shortcuts. Frames are stored on the clipboard as tab-separated text, so you can cut them from the frame list, paste them into a spreadsheet program, edit them, and then copy them back in to the frame list when you are done. (This feature does not work in Linux.)
Keyboard Shortcuts
The following keyboard shortcuts can be used in the frame list:
  • Ctrl+A: Select all frames.
  • Ctrl+C: Copy selected frames.
  • Ctrl+V or Shift+Insert: Paste/insert frames from clipboard.
  • Ctrl+X: Cut selected frames.
  • Ctrl+Up: Move selected frames up.
  • Ctrl+Down: Move selected frames down.
  • Del: Delete selected frames.
Mini Maestro 18-Channel USB Servo Controller (Assembled)
Mini Maestro 18-Channel USB Servo Controller (Partial Kit)
Mini Maestro 24-Channel USB Servo Controller (Assembled)
Mini Maestro 24-Channel USB Servo Controller (Partial Kit)
