3. Compiling avr-gcc
The latest versions of GCC (4.2.3 and up) include support for the ATmega328P, as well as the ATmega48P, ATmega88P, and ATmega168P.
Checking the currently installed version of avr-gcc
Run the following command:
avr-gcc --version
You can test for support by creating an empty file test.c and running avr-gcc -mmcu=atmega328p test.c. If your version of gcc does not support the chip, you will see the following errors:
unknown MCU 'atmega328p' specified
test.c:1: error: MCU "atmega328p" supported for assembler only
Installing prerequisites
Recent versions of GCC (4.3.x) depend on GMP and MPFR, which can be installed from their web pages. Under Ubuntu, you can get these packages by running the following command.
sudo apt-get install libgmp3-dev libmpfr-dev
Other distributions probably provide similar packages.
Downloading the source code
Get gcc-4.3.3.tar.bz2 or a later version from the GCC FTP site or from a mirror closer to you if possible. We recommend getting the full GCC, which includes the C++ compiler, not just gcc-core.
Unpack the archive
tar xjf ~/Desktop/gcc-4.3.3.tar.bz2
cd gcc-4.3.3
Configure, compile, and install GCC
Note that you need to compile GCC from a separate directory, and that we are specifying that only C and C++ be included. If you want to try compiling FORTRAN, ObjectiveC, or GCJ for the AVR, you’re on your own!
mkdir build
cd build
../configure --prefix=/usr/local --target=avr --enable-languages=c,c++ --disable-nls --disable-libssp
make
sudo make install
Next steps
The latest version of avr-gcc should now be on your path. Next, proceed to Section 4 to install avr-libc for all of the AVR microcontrollers supported by GCC.
New Products
Motoron M3H550 Triple Motor Controller Kit for Raspberry Pi
3.3V Step-Up/Step-Down Voltage Regulator S8V9F3
150:1 Micro Metal Gearmotor MP 6V with 12 CPR Encoder, Back Connector
DRV8434 Stepper Motor Driver Carrier (Header Pins Soldered)
6V Step-Up/Step-Down Voltage Regulator S8V9F6
ACS72981KLRATR-150B3 Current Sensor Compact Carrier -150A to +150A, 3.3V
ACS71240KEXBLT-050U5 Current Sensor Carrier 0A to 50A, 5V
RoboClaw 2x200A, 60VDC Motor Controller
Zumo 2040 Robot (Assembled with 50:1 HP Motors)
