2. Compiling binutils
Checking the currently installed version of avr binutils
Run the following command:
avr-as  --version
Downloading the source code
Get the latest version from the binutils FTP site. We tested these instructions with version 2.19.1.
Unpacking the archive
tar xzf ~/Desktop/binutils-2.19.1.tar.gz
cd binutils-2.19.1
Configuring and compiling binutils
The options given here just specify that the AVR version of binutils should be compiled:
./configure --prefix=/usr/local --target=avr
make
sudo make install
Next steps
You should now have the latest version of all of the binutils utilities compiled for the avr and installed in your /usr/local/bin. Proceed to Section 3 to install avr-gcc.
New Products
298:1 Micro Metal Gearmotor LP 6V with 12 CPR Encoder, Side Connector
Graphical OLED Display: 128x64, 1.3", White Pixels, SPI, Black PCB
4.2-15V, 3A Fine-Adjust Step-Down Voltage Regulator D30V30MAS
298:1 Micro Metal Gearmotor LP 6V with 12 CPR Encoder, Back Connector
ACS724LLCTR-20AU Current Sensor Carrier 0A to 20A
3.3V Step-Up/Step-Down Voltage Regulator S8V9F3
ACS72981LLRATR-050B3 Current Sensor Compact Carrier -50A to +50A, 3.3V
ACS71240KEXBLT-050U5 Current Sensor Carrier 0A to 50A, 5V
DRV8434 Stepper Motor Driver Carrier
