Support » Pololu Maestro Servo Controller User’s Guide »
9. Maestro Settings Limitations
Mini Maestro serial baud rate limitations
On the Mini Maestro 12, 18, and 24, the following baud rates should not be exceeded, or the processor may become overloaded, causing degraded performance.
| 10–100 Hz | 111–250 Hz | 333 Hz | |
| Serial mode: UART/USB chained* | 200 kbps | 115.2 kbps | 115.2 kbps |
| Serial mode: Dual-port | 115.2 kbps | 57.6 kbps | 57.6 kbps |
* Assuming bytes are not sent and received simultaneously, as required for the Pololu protocol.
Micro Maestro pulse length limitations (high pulse rates only).
Most servos are designed for 50 Hz operation. Unless you know that you need high pulse rates, you can safely ignore this section.
The Micro Maestro has a restricted maximum pulse length for pulse rates of 67 Hz and higher. The restriction depends on the Servos available setting and is enforced automatically by the Maestro Control Center.
The maximum pulse lengths in microseconds are given below:
| 6 servos | 5 servos | 4 servos | 1–3 servos | |
| 67 Hz | 2448 | 2944 | 3000+ | 3000+ |
| 71 Hz | 2272 | 2736 | 3000+ | 3000+ |
| 77 Hz | 2112 | 2544 | 3000+ | 3000+ |
| 83 Hz | 1936 | 2336 | 2944 | 3000+ |
| 91 Hz | 1776 | 2144 | 2688 | 3000+ |
| 100 Hz | 1616 | 1936 | 2448 | 3000+ |
Mini Maestro servo pulse length limitations (high pulse rates only)
On the Mini Maestro 12, 18, and 24, pulse rates of 200–333 Hz put restrictions on the servo pulse lengths. These restrictions apply to all servo channels, even if some are set to a lower pulse rate using the Period multiplier feature.
The following tables show allowed minimum and maximum pulse lengths, in microseconds, for a variety of combinations of pulse rates and servo numbers. All enabled servos must always satisfy the restrictions on some table row, so the easiest way to follow the restrictions is to pick a row, then configure minimums and maximums for specific channels according to the restrictions given in that row. However, you do not need to specify the ranges of your servos in advance: you can switch some channels off or adjust their positions to access a wider range on other channels. If your settings happen to violate these restrictions, the servo period might increase and the units of speed and acceleration limits will change accordingly, but the operation of the Maestro will not be affected in any other way.
For example, with a Mini Maestro 24 running at 250 Hz (a 4 ms period), you may use 12 servos with a range of 576–2880 μs and 6 servos with a range of 64–2880 μs. The remaining 6 channels must each be off or have their mode set to Input or Output (not Servo).
| Allowed pulse ranges at 333 Hz: | |||||||||||||||||||||||||||
| Allowed pulse ranges at 250 Hz: | |||||||||||||||||||||||||||||||||
| Allowed pulse ranges at 200 Hz: | |||||||||||||||||||||||||||
