Arduino Library for the Pololu QTR Reflectance Sensors
Arduino IDE with Pololu QTR sensors superimposed over it.
1. Introduction
2. Library Installation
3. QTRSensors Methods & Usage Notes
New Products
Glideforce GF01-121003-2-66 Micro Linear Actuator with Feedback Potentiometer: 12V, 4.3kgf, 17.6mm/s, 30mm Stroke
5V, 300mA Isolated Step-Down Voltage Regulator D24Z3F5
9V Step-Up/Step-Down Voltage Regulator S9V11E2F9
ACS37030LMYATR-065B3 Current Sensor Large Carrier -65A to +65A, 3.3V
APM81815 Step-Down Voltage Regulator Carrier, 5V Out
Magnetic Encoder Pair Kit with Side-Entry Connector for Mini Plastic Gearmotor, 12 CPR, 2.7-18V
ACS37100LMATR-025B3 TMR Current Sensor Compact Carrier -25A to +25A, 3.3V
20.4:1 Metal Gearmotor 25Dx65L mm HP 24V with 48 CPR Encoder
